FS: 4th gen part out/garage sale incl. VQ35 parts/turbo related parts
This thread will have remaining parts from my 4th gen part out from my record setting stock white 1995 winter beater, as well as some parts from a VQ35 or two, and some misc parts that I just have laying around. All prices are shipped unless otherwise noted. All prices are OBO unless otherwise noted. If I don't have a price listed I apologize I will be adding and editing this post as I uncover stuff in all my boxes in my storage unit - PM me or post if I don't have a price and I will price it. Most of the stuff has pics posted or available, a few things I forgot/didn't bother to take pics of. Let me know if you require a picture of something.
7 (yes seven) BKR7EIX NGK Iridium spark plugs. Had these in my turbo car for only a couple thousand miles before I did my 3.5 swap and went back to NA, obviously don't need the 2 step colder iridiums anymore. 6 are used for a couple thousand miles and still in perfect shape, and one brand new in box as a spare. $35 shipped for all 7 of them.
Also have my Blitz DTT DCII (DC2) turbo timer and boost gauge for sale. Works great. Digital boost readout in kPa. Includes the harness and vacuum line. $40 shipped
I also have an Apex'i AVC-D boost controller as well, but I'm not sure if I want to sell it (still would like to re-turbo this car some day and I love this boost controller). PM me if interested in the AVC-D.
2002-2003 throttle body $90
BRAND NEW shiny and clean 2002-2003 Throttle Body that I started disassembling for use with 4th gen cable throttle conversion $45
Two 02-03 VIAS vacuum canisters(these have built in check valves) and attached map/baro sensors/vac lines $25
TWO 4th gen throttle bodies $30 (only one pictured because of 15 picture limit)
BRAND NEW sealed in plastic Deatschwerks stock 4th gen injector $35 (don't go pay $80 at the parts store or $120 from nissan for a new stock injector)
5 (yes five) VQ35 coilpacks $50
a pair of 8mm wheel spacers $25
2 USIMs $20+shipping
4th gen LIM $15+shipping
Three 4th gen TPS Throttle Position Sensors
Billet battery tie down (not Stillen) $20
Brand new in box VQ35 Thermostat $20
4th gen Thermostat $15
4th gen IACV $40
two pairs of BRAND NEW IN PACKAGING Speed Bleeders $25
4th gen manual climate control $15 (I think it has some burned out lights inside of it, IIRC)
4th gen center vent assembly with working hazard and defroster switch $15
4th gen window switches for all 4 doors $20 for all 4 as a package
1 Brand new OEM (not aftermarket) and one used OEM 4th gen ignition switch $25 new, $15 used
Mirror tilt switch $10
Cruise control switch $10
Polished aluminum VQ30 front valve cover $65 (it's a bit dirty in the pic, cleans up nicer than it looks in this pic).
4th gen brake master cylinder
Various CPS REF, CPS POS, and other engine sensors (no O2 sensors though)
Generic strut bar with either red or blue mounting brackets (have a set of red and a set of blue). $20+shipping since I don't know how much shipping this large thing will be. PM me and we'll figure it out.
BCM from 95 GXE 5spd (also known as interlock control unit, interlock control assembly, body control module - this bad boy is $1088 from Courtesy Nissan). Asking $80.
11 tooth 4th gen starter - this came from my winter beater which was the fastest starting vehicle i've ever owned.
4th gen VSS Vehicle Speed Sensor
4th gen IACV $40
I don't know what is going on with this new marketplace saying my partout is "sold" but nothing is "sold" yet. I have to find the thing first and Jsutter definitely has first dibs on it from like 2 years ago, if I can even find it.
Oh well.
I will check if they are OEM or not. I assume they are, I never had to replace them and owned the car since 2004 so unless they were replaced before that they are OEM. Will check for sure.
I am sure with the knowledge between the two of us we could get it installed and working properly for you. I just searched google and found a number of writeups, including one from the .org, as well as the instruction booklet for it.
how much for the boost controller?
max_speed97
Aug 26, 2015 07:46 PM
kirkhilles
Aug 8, 2015 10:53 AM
BassAddictJ
Aug 4, 2015 11:38 AM
