throttlebody bolt stripped
Old Aug 27, 2013 | 09:55 PM
maxx0831's Avatar
Hey everyone. I finally got around to installing the 5pc nwp spacers last weekend. The only problem I ran into was getting the throttlebody off to install the spacer. I got 3 out of the 4 bolts out. The one bolt i cant seem to get off is the lower left bolt. I stripped it and no matter what I use, I cant seem to get a vise grip or a needle nose onto that bolt bc its a tight space as well as a bracket is in the way too. Im sure some of you had some problems with the throttlebody getting it off. Can you offer me any other ideas? Thanks
Old Aug 27, 2013 | 10:25 PM
bennuss's Avatar
CAn we get a picture?
Old Aug 27, 2013 | 10:30 PM
MrEous's Avatar
^ Jeff™
Drill it and easy-out it?
Old Aug 28, 2013 | 07:57 AM
NmexMAX's Avatar
dot dot dot ...
Remove, manifold w/ TB attached and add some elbow grease.
Old Aug 28, 2013 | 08:40 AM
maxx0831's Avatar
Ill try and get a picture of it. I didnt want to mess with the throttle body too much and unplug it and then the ecu wont take the relearn. But if i have to then I will. Ill probably take it to a shop to see if they can take it out. I thought of drilling it but kept thinking i will damage is bc of how sensitive the throttle body is.
Old Aug 28, 2013 | 09:26 AM
knight_yyz's Avatar
Toolie
Grind the head off
Old Aug 28, 2013 | 09:56 AM
maxx0831's Avatar
Could I be able to use a dremel to cut a slit into the bolt head and maybe use a flat head screw driver and hammer it to break the bolt loose?
Old Aug 28, 2013 | 11:53 AM
NmexMAX's Avatar
dot dot dot ...
Seems like a bad idea.
Old Aug 28, 2013 | 12:45 PM
knight_yyz's Avatar
Toolie
actually that is a tool and die trick
Old Aug 28, 2013 | 01:16 PM
NmexMAX's Avatar
dot dot dot ...
Was hoping you'd chime in with that, I nearly said check with knight, he'll know what t do.
Old Aug 28, 2013 | 01:27 PM
02whitemaximase's Avatar
A trick also good for removing stubborn bath tub drains. I think removing the manifold with the tb attached and the dremel trick would work perfectly together. I would worry about unplugging the tb.
Old Aug 28, 2013 | 04:37 PM
knight_yyz's Avatar
Toolie
Or, if you remove the manifold, you can actually physically turn the TB in the proper direction since there is only one bolt left (anti clockwise). That may cause the bolt to loosen as well. I'm not sure if there is enough room to do it with the manifold bolted up.
Old Aug 28, 2013 | 06:17 PM
maxx0831's Avatar
Ill try that knight. the space is so tight I cant get anything to get grip out that bolt especially with that little braket screwed underneath that bolt as well but Ill try it though. Ive taken the manifold off but had the throttlebody still plugged in.
Old Aug 28, 2013 | 06:46 PM
Child_uv_KoRn's Avatar
Bad *** Newb
The TB isn't very sensitive. You could take it out and throw it around on the ground like a ball and as long as you don't break the electronics on the side it would be fine.
It gives no ****s if it's plugged in or any superstitious stuff like that. You're not going to be fingering the plate.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
