2013 maxima issues and only 18,000 miles
okay so when i accelerate sometiems there is a red break light that comes on on my dash board ? the same light that comes down when you hit the e-break does anyone have a clue why that happens ? and sometiems when i am flooring it to 100+ speeds the engine litertly cuts off on a lag as if there is a safety divice ? please somone tell me im no the only person . Also has anyone ever tried converting a DE to an HR ? just out of curiosity
Might be low on brake fluid, might have a short in the e-brake wiring harness, might have a loose ebrake pedal. Are you sure it isn't the traction control light?
Why not take it to the dealer since it is likely under warranty?
To my knowledge, there is no safety device in place that should cut engine power at 100 mph or over, but unless you are on a track, that's just plain dangerous speeds friend.
I'm a lawyer and in my state, that's a class A misdemeanor, punishable by up to 364 days in jail and up to a $2500 fine.
Can you explain what "converting a DE to an HR" means?
You might be low on Brake fluid, but I'd check for any leaks since 18,000 miles is too soon to be topping off brake fluid. And if you search, you'll find that these cars pretty much stop accelerating after 100-120. Some say its the governor, some say torque converter.
PS If you are into racing cars you picked the wrong car for your type of driving
It's not that the engine has a governor that limits speed rather a sensor that prevents the tranny from over heating. You must be creating lots of stress getting to 100 mph for your engine to sense this. Your tranny is the heart of your engine you need to manage it in order to maximize performance.
top off your brake fluid, low brake fluid will disable VDC and cause your e-brake light to come on occasionally. literally top it off completely in the master cylinder reservoir in the engine bay.
regarding going 100+ and having the car start having issues, you COULD be limping the transmission but this usually just means you won't be able to rev over 4000 RPMs - has nothing to do with your speed. if you're having issues only related to speed and can still rev, could be something else.
FanaticMadMax
Aug 10, 2015 08:55 PM
