03 6mt po300 & p1800
I have a 03 6MT Titanium Edition with 124K on it with the 2 dreaded codes PO300 and PO1800 I changed my spark plugs and checked all 6 Coilpacks they are all good I got a NWP block off plate to delete the VIAS to see if that would help but the code still remains I cleaned the MAF and changed the PCV and still have the same **** the check engine light blinks at idle only but ONLY at idle I recently found a giant *** hole in my O2 sensor and I was wondering could this cause my problem? I have video and pics to prove my issue here Thanks guys
p1800 is not related, so ignore that. Random misfire could be plugs or oil in the tubes. I'm not sure if over advanced timing could only affect idle or not (that would be a VTC solenoid).
I'm not sure what you mean with the O2, but if you want to rule it out just unplug it.
If you haven't changed the plugs, then do that.
P1800 is the VIAS Control Solenoid Valve.
See page 638 - http://boredmder.com/FSMs/Nissan/Maxima/2003/EC.pdf
Derrick2k2SE
Aug 12, 2015 06:47 PM
MikesChevelle
Aug 7, 2015 05:57 PM
MikesChevelle
Aug 6, 2015 11:36 AM
