? Regarding 5.5 motor mounts
Old Oct 9, 2013 | 05:07 PM
tseng1023's Avatar
About to replace all 4... Just wondering do I have to replace the one w/ sensor with one that has sensor? I heard it's not needed. Just want to make sure...
Old Oct 9, 2013 | 06:48 PM
NmexMAX's Avatar
dot dot dot ...
I replaced mine without a sensor. Been fine ever since.
Old Oct 9, 2013 | 07:52 PM
george__'s Avatar
If you have automatic car... The car was less refined?? after switching to the ES mounts / mounts made by Knight. Like after getting all 4 to stiffer ones my rear view mirror vibrated like when you are listening to very bassy music and especially in idle, the entire interior vibrates. But it also helped (almost killed) the 1-2 hard shift from the transgo kit.
Old Oct 9, 2013 | 08:18 PM
CauzinDrama's Avatar
Knights poly mounts FTW!
Old Oct 11, 2013 | 08:29 AM
Brl24's Avatar
Where are you buying your mounts tseng?
Supposedly the eBay sets are decent for the money.
Old Oct 11, 2013 | 08:40 AM
jr schultz's Avatar
What I did to help this problem out was raise my idle to 900 RPM's using Car Gauge Pro app.
Old Oct 11, 2013 | 09:02 AM
Wow that's high. I have mine around 775 and it's smooth. You must burn alota extra fuel?
Old Oct 11, 2013 | 09:41 AM
jr schultz's Avatar
That's what the tack says, but it varies. I can't remember what number I actually set the rpm to via the app. I haven't noticed a difference in fuel economy, although I'm sure it is down a bit.
Old Oct 11, 2013 | 09:55 AM
george__'s Avatar
Is that even safe?
the car is idling ~600 rpm range (checked using nissan OBD tool )
can the nissan obd tool be used to raise the rpm permenately to 700 range?
Old Oct 11, 2013 | 11:01 AM
tseng1023's Avatar
Thanks Nmex... You can lock this before more rambling of the above poster continues.
Old Oct 11, 2013 | 11:08 AM
Brl24's Avatar
Was my question not considered valid?
Old Oct 11, 2013 | 11:16 AM
tseng1023's Avatar
It was directed at george... I bought them off someone who had multiple sets for sale. Google ES mounts for our car it's not hard to find.. Everything is on google
Old Oct 12, 2013 | 10:26 AM
Brl24's Avatar
Yah I can find the ES mounts on my own lol
I was under the impression you were just buying stock mounts, and was curious where you were getting them as I will be needing a set soon.
Did you buy inserts or mounts with the insert already installed?
Old Oct 12, 2013 | 12:27 PM
JWatZ's Avatar
NWP torque brace caused the same behavior with OEM mounts. Can't imagine how bad it will be when I get around to poly filling my mounts.
Old Oct 12, 2013 | 02:17 PM
george__'s Avatar
You should reinforce the glove box with foam as well. There's a service bulletin somewhere about it.
Good luck
Old Oct 12, 2013 | 03:10 PM
Maverick4189's Avatar
Good luck
Im sorry but what?
Old Oct 12, 2013 | 03:11 PM
Good luck
Don't know why I'm asking this but , WHAT?
Old Oct 12, 2013 | 03:19 PM
JWatZ's Avatar
Good luck
Huh?
Old Oct 12, 2013 | 03:26 PM
george__'s Avatar
After the mounts got done the glove box vibrated like crazy. Had to use tape foam stuff and applied it but didn't fix the issue 100%. Dealership helped even further when I did recall so now it's almost gone
http://s918.photobucket.com/user/mor...56f05.jpg.html
http://s918.photobucket.com/user/morydees/media/NTB99-056f07.jpg.html
maxima.org were the ones who told me about the fix..........
Old Oct 12, 2013 | 03:28 PM
lay off the crack dude
Old Oct 12, 2013 | 05:56 PM
tseng1023's Avatar
The inserts were installed.
Old Oct 12, 2013 | 06:21 PM
Rods03Max619's Avatar
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
