VA Part out 97 Black on Black Full swap lots of mods
Old Jan 6, 2014 | 02:45 PM
sergofast's Avatar
If you see it listed it is STILL AVAILABLE. All parts (except Springs/rotors are priced with shipping - First one with cash gets the parts...
[LIST][b]
All sales on used parts are final.
Old Jan 6, 2014 | 03:15 PM
brandnew's Avatar
im interested in the kevlo led tails board, either the eibach or progress springs depending on which one is more comfortable and closest to an inch drop, also want the budget y pipe, if the tl projectors are a complete retrofit im interested in that too, interested in front and rear strut bar or the progress rear sway bar
Old Jan 6, 2014 | 03:46 PM
sergofast's Avatar
$40 shipped - 4th or 5th gen blower motor (quite and works perfect)
Walboro Fuel Pump - $60 shipped
Window switches - $40 shipped
SuperPro Front control arm bushings (these look rough but are still good) $15 shipped
97 BCM - $25 shipped
Custom LED interior lights (soft white/blue) 6500 kalvin iirc - $50 shipped for all four (door panels, dome light, map light with sunroof control)
Old Jan 6, 2014 | 03:50 PM
maxprivate's Avatar
Black Lion
Post pics of your engine bay. I want to see how your oovi looks installed. check your pm
Old Jan 6, 2014 | 03:52 PM
theblackone3.5's Avatar
pics of the cattman headers?
Old Jan 6, 2014 | 03:58 PM
brandnew's Avatar
Originally Posted by sergofast
Your going to want the Progress springs for sure...The eibachs are more of a drop. The TL projectors are a complete retrofit and they look great. Ill get some pics up for you.
One other member has spoken for the Kevlo boards but if he doesnt get them they are yours.
if you buy all this stuff together Ill help you out with the shipping. Whats your zip?
shipping to 33596 the kevlo boards and retrofit are my priority and then the springs and the y pipe those are the four i want the most... but i really need the kevlo boards
Old Jan 6, 2014 | 04:03 PM
97SEstick's Avatar
Interested in kevlo light boards, budget y pipe,& hid headlights
Old Jan 6, 2014 | 04:07 PM
sergofast's Avatar
Ill have pictures up by tomorrow, its dark out now so Ill take them in the morning: Im posting your PM here for all to see in case anyone else wants to know details on the 00vi:
Hi,
oovi conversion, is this a direct bolt on now that you have modded it to fit your max?
I have the MEVI now but didnt get the results I was looking for now that Im boosted SCd. Maybe consider your 00vi since I read its more beneficial than the MEVI
I had a stock vq30de when I got the 00vi. Its a direct bolt on for the 4th gen, you will just have to rout the vacuum hoses correctly. If you have installed the MEVI it wont be a problem for you at all. My only concern about the setup that I have and you being boosted is that not ever single one of the bolts are used to connect the upper to the lower. That being said, nothing has been modified on the 00vi so if you had an issue with it leaking you would simply have to swap out the 4th gen lower piece with a 5th gen lower and it would all bolt up perfectly.
The conversion I am using is the following:
  • 00vi upper - not modified with VIAS delete
  • 4th gen lower (flipped 180 degrees) - This piece StephenMax plugged all the holes and re drilled the mounts so that the ports line up exactly with the 5th gen upper (if you read about this you will find that typically when you flip the lower it doesnt line up exactly). I did this so that I wouldnt have to mess with changing to 5th gen injectors.
  • 4th gen injectors
  • StephenMax IAVC adaptor plate (the triangle looking custom piece you will find pictures off around the forum)
  • 5th Gen TB with the coolant passage blocked off.
Old Jan 6, 2014 | 04:24 PM
sergofast's Avatar
Cattman was sold...
Old Jan 6, 2014 | 04:33 PM
electr0lyte's Avatar
Willing to part with that custom 5 speed timing ring?
Old Jan 6, 2014 | 04:38 PM
sergofast's Avatar
Sure...That thing cost me $200 to get fabricated (its a work of art). Ill sell it to you for $175 plus shipping.
Old Jan 6, 2014 | 05:05 PM
Excalibur23's Avatar
I just pmed you after I saw your car for sell, regarding partout. Lol
Old Jan 6, 2014 | 06:27 PM
Blood on Black's Avatar
pm sent
Old Jan 6, 2014 | 09:16 PM
Joey SR's Avatar
Shipping for the cattman headers to 07505?
Old Jan 6, 2014 | 10:49 PM
sergofast's Avatar
PMs replied. Im not going to qoute shipping prices until I decide if I am actually going to part it out....that just takes too much time. the good news is I have a business UPS account and get fairly decent shipping prices...so dont worry about that too much.
Old Jan 6, 2014 | 11:00 PM
Fakie J Farkerton's Avatar
Still waiting to hear back from you about the timing ring...
Old Jan 9, 2014 | 02:58 PM
sergofast's Avatar
Photos added.
Old Jan 9, 2014 | 03:06 PM
Amerikaner83's Avatar
entire set of window switches, master and 3 passenger?
Old Jan 9, 2014 | 03:39 PM
sergofast's Avatar
They all work. $50 shipped.
Old Jan 9, 2014 | 04:31 PM
Slamrod's Avatar
Is that fender-air intake setup (minus MAF) for sale? If so, does the MAF adapter happen to be aluminum? Cant find one of those anywhere.
Old Jan 9, 2014 | 05:01 PM
sergofast's Avatar
Everything you see is for sale... PM sent.
Old Jan 9, 2014 | 09:22 PM
Slamrod's Avatar
Didnt get your PM.
Old Jan 9, 2014 | 10:08 PM
Dwolniak's Avatar
b&m shifter have all parts needed?
Old Jan 10, 2014 | 12:55 PM
eddie982's Avatar
I sent you a pm yesterday
Old Jan 10, 2014 | 08:48 PM
sergofast's Avatar
Yes. Its on the car now and working just fine. The only thing I dont have is the actual B&M shift **** but all of the actual shifter pieces are there.
Old Jan 11, 2014 | 08:44 PM
Jason R's Avatar
aka UNCDooD
I might be interested in the vlsd trans and im local!
Old Jan 11, 2014 | 08:50 PM
deathwobble's Avatar
The stainless steel brake lines. Is that for 4 or 2?
Old Jan 12, 2014 | 08:10 PM
avin's Avatar
hey man
are we still doing the struts and Springs
N5V4V4 London Ontario Canada
Old Jan 12, 2014 | 10:38 PM
milo2223's Avatar
Am interested on front and rear strut tower bars! PM sent...
Old Jan 13, 2014 | 01:01 AM
vq4thgen4life's Avatar
3" Cattman Catback
Next in line for that 3" Cattman Catback
Also interested in headlights and both Strut Bars. If those go, I am willing to pay you to ship me that trans.
Old Jan 13, 2014 | 07:58 AM
Slamrod's Avatar
Also interested in PR Intake and both Strut Bars.
Already got dibs on the CAI
I think a major problem here is the seller has another thread up where hes selling the max as a whole with all these parts. So basically theres a good chance everyone here will leave empty handed despite having their names put on the buying list.
Old Jan 13, 2014 | 11:02 AM
schmellyfart's Avatar
Interested in the Blhemco lower tie bar. Do you have any pics of it?
Old Jan 13, 2014 | 02:03 PM
sergofast's Avatar
Actually...dont let that bring you down. Im not getting much interest with selling it as a whole. Theres one guy who contacted me but he hasnt been responsive so Im probably 95% sure going to start pulling parts. I will not leave this thread without feedback.
Old Jan 13, 2014 | 11:34 PM
Dibs on 5th gen calipers?..
Old Jan 26, 2014 | 01:09 AM
I will make a decision within two weeks on if I am going to part it or not so be patient with me please.
Bumping for OP's two week update.
Old Jan 26, 2014 | 10:09 AM
6cyl-97maxima's Avatar
I want that y-pipe! If the others don't follow through with the purchuse pm me. Are those headers already called.for too?
Old Jan 26, 2014 | 10:20 AM
There are two people in line for the headers.
You would make #3 unless someone else PM'ed him already.
Old Jan 27, 2014 | 01:20 AM
i think he's on FB too, I swear I seen these exact parts on a FB page
Old Jan 27, 2014 | 04:06 AM
Slamrod's Avatar
Im #2 on that list, and i can tell you that there is 0 chance whatsoever of you getting the cattmans lol. I have the money set aside if the first guy falls through which is sadly unlikely.
Also sergo i pm'd you a couple of times about that cai a week or two ago, not sure if someone pm'd you first but if not throw my name up there.
Old Jan 27, 2014 | 04:54 AM
Climaxx's Avatar
I'm interested in the tail lights if you're willing to part those out.
