Which is the drive wheel (most tire wear)?
Which front wheel is the drive wheel? I have uneven tread depth in the front and forgot to check which side before taking in for balance and rotation, so I don't know if they rotated the fronts to even out the wear.
Fwd doesnt torque load like a rwd solid axle. It will wear pretty evenly and wheelspin will be pretty random. I suspect you have a n alignment issue or you have a particular corner in your daily commute that wears a particular front tire faster.
