98 Maxima Drivetrain
Old Feb 23, 2014 | 04:15 PM
hollowground75's Avatar
98 Maxima Drivetrain Someone Please Help I am Desprate
I am new here but I was wondering on a 98 maxima what consists in changing the the throw out bearing. I am purchasing a clutch kit and was wondering should I pick up a flywheel also and I am doing it myself with help of a friend. I am very mechanically incline just never done a clutch on a front wheel drive and I am curious at what I'm getting in to........ Thanx in advance ........ Also I can not find anything on the web to even give me an idea but I will be purchasing a Haynes manual.
Old Feb 23, 2014 | 04:37 PM
Someone please help I'm in a desperate need
Old Feb 23, 2014 | 05:03 PM
maxima.713's Avatar
If you are very mechanically inclined what help is it that you need?
Old Feb 23, 2014 | 05:37 PM
Aflion's Avatar
All you do is drop the transmission, and everything is right there. You shouldn't need a new flywheel. If needed, your stock one should be able to be resurfaced. It's extremely straight forward if you're mechanically inclined.
Posted from Maxima.org App for Android
Old Feb 24, 2014 | 05:29 AM
asand1's Avatar
Pull both axles. Be ready to lose atf/gear oil.
Look for the member named "the wizard" he has a link to the repair manual pdf in his signature line.
Old Feb 24, 2014 | 05:52 AM
dwapenyi's Avatar
You can find all the info on the 4th gen how to's here;
http://forums.maxima.org/4th-generat...on-maxima.html
Here's the clutch job how to from motorvate;
http://web.archive.org/web/200804300...ca/mvp.php/801
Since you will be removing axles, you will lose tranny fluid. Replace with GL-4 only. Redline MT90 is a well regarded upgrade to your GL-4 tranny fluid.
Old Feb 24, 2014 | 08:17 AM
Thanx for all the info it is greatly appreciated and meaning mechanically incline I'm no licence mechanic and know a lot about your basic engine I.E. GM your standard muscle car but as far as front wheel drive this is my first just want to make sure I'm doing it right and not doing extra work I like to work smarter not harder lol
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
