LuminousX 96 Maxima
Old Mar 6, 2014 | 01:33 PM
LuminousX's Avatar
LuminousX 96 Maxima
Here's a look at my 96, if i had pictures of how it looked when i first got the car you'd see how much I've cleaned up the car, and such... for those that don't understand Jamaican talking, sorry, i didn't make the video for the site, it was for a friend as i started in the video
Since I've got the car I changed
1. Knock Sensor
2. Revolution Speed Sensor
3. Front Coil Park (2 times, aftermarket coil threw a code)
4. Both lower Control Arms
5. Cleaned , And Replace All Fuel Injectors O-rings
6. Brand New Radiator, Change Corrosive Radiator water to Coolant (lols)
7. Replace A Corrosive Water Pump that broke into piece when the water frost around it
8. Valve Cover Gasket (Rear)
9. Change Front Brake Pads
10. 4 used tires
11. 6 New NGK Spark Plugs
12. Gas Cap
when i remember move I'll add to the list
I bought my car on Sep 30, 2013
Old May 14, 2014 | 07:12 AM
minipudd5's Avatar
Dude im lovin everything you do inside of the car. its pretty cool that you have the whole touch screen in there and have it linked to your radio, you gave me an idea for my car now
a cool and cheap thing you could do to the plastic on the inside is vinyl wrap. its like carbon fiber kinda but its not, idk its weird to explain but you get a whole sheet of it, cut it up to match the part you want to wrap, peel the adhesive off and stick it on, then you gotta trim it with an exact o knife. i wish i had a picture of mine but it ended up turning out really good. its a good cheap way to make the interior more better looking.
Old May 14, 2014 | 09:20 AM
LuminousX's Avatar
thanks, I've already spray painted inside my maxima already, check out the video
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
