the funniest radiator leak
My 03 max has a very annoying radiator leak. I'm trying to find an adhesive that will seal it, although I've tried a few and I cannot replace the rad right now (unemployed). It doesnt leak a whole lot, but every two to three weeks I have to refill the rad about a half liter. The leak comes from the Nissan tag on the top part. I swear to gawd. Where the little Nissan logo is, on the right, there is a small leak that i see and hear when I squeeze the hose. I've tried a few things, but it's still leaking a little.
What should i do?
What should i do?
Order this:
And a case of these:
And you should be ok for a while.
TYC Part # 2329 {#214605Y700, NI3010113} Complete Radiator Assembly One of our most popular parts
[Flag indicates this part fits vehicles sold in the US Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide.] [Flag indicates this part fits vehicles sold in the Canadian Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide.] [Flag indicates this part fits vehicles sold in the Mexican Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide.] Bottom Header: 1 7/16" x 28 1/16"; Core Size: 15 3/4" x 27" x 5/8"; Plastic/Aluminum; Rows: 1; Top Header: 1 7/16" x 28 1/16"
Part Image
* Stocked in outlying warehouse--shipping delayed up to 1 business day
$49.79
I guess you could empty the radiator then try and clean the crack really good and use some epoxy.
Like 3 or 4 years ago, I had a leak at the top of my radiator and I used JB weld or something similar and it actually lasted quite a while, although I did end up changing the rad though.
Sorry best advice is to just fix it by replacing it. If you have the slightest bit of mechanical knowledge you can do it yourself. Very easy job.
This is not an expensive repair either. As of right now anyways.
Overheat it and you risk blowing head gaskets or worse. Spend $100 now or $2000 later...
Those cooling system sealants and such clog the cooling system and gum up. Do not use. If you don't have access to $100 for a repair you seriously need to re-asses your financial status.
Actually he can get one for 49.79, this one is a very popular one for 5th gens from http://www.rockauto.com/
Part Image
$49.79
Part Image
$49.79
Good deal right there...
I drove my 4th Gen with leaking radiator for a while. When the time came I just replaced it. The down side is that if it gets worse, you might be stuck on the side of the road. Seems like there are cheap options if you just want to replace it now. Good luck!
you cant patch the radiators on plastic rads, the plastic is made up of polyethelyne. nothing will bond to that plastic, and nearly all plastics today are made up of it. only rads you can patch with JB weld or whatever are metal rads
Duct (duck) tape? Don't eat fast food for a week and you have a new radiator. Walmart has coolant for $10 a jug. Follow the correct procedure; cliff notes, heater on full hot full blast, leave radiator cap open and fill the system. Run engine. This allows all air to escape. Good luck. Sorry for your financial situation but take our advice and don't make it worse.
a lot of the advice here is going to result in a blown motor. don't try to melt the crack closed, don't keep driving it. It may suddenly breach letting out a lot more coolant than it has been, catching you off guard.
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
