Varrstoen es2 or keep g35 rays?
So, I am currently rolling on g35 rays 19s on ksport coilovers:
I am about to do a suspension overhaul, complete with Tein street advance coilovers to replace my Ksports. I am definitely going to go lower with my new setup. I like the stock look my g35s give me, but I think I want something more flush and aggressive. Heavily considering these:
They are Varrstoen es2 . Here are some picks of them on a 4th gen on here
Size would be 19x19.5 all around with probably a 12mm offset. They also offer a 22mm and 30mm offset.
Question 1: What is your opinion? Which wheels should I buy/keep
Question 2: Will the Varrstoens fit? I want a flush look but definitely no poke.
I'm thinking 225/40/19. Yeah I'm kind of lost on what offset I need to run. What would make +30 the right offset? I want them to sit pretty flush. I'm going to get the same offset on front and back so I can rotate tires without a hassle.
Does anyone know what offset I should run? The more reading I do, the more I'm thinking I should do the +30, but I'm still confused
Are you lowered or will be lowered? If so, what suspension setup?
p.s. if you look at the picture in my sig, you will see 9.0" +30 in the front. Hope this helps.
I am on ksport coilovers now, going to tein SA at the same time I do the wheels. So tell me if Im right, the g35s are the same offset (+30) and 8 inches wide, so if I go with these 9.5 inchers, they will sit 3/4 of an inch further out? That would be about right in the front I think and I would probably even need a small spacer in the rear.
fml, I just realized they dont make a +30 offset In the hyper black only matte black, but I guess I can call them and see if they can, dont see why they couldn't
I have no idea for the service rate at your location but in SoCal they run roughly $200.
NewMax03
Oct 7, 2015 08:27 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
03VQMAX
Sep 5, 2015 03:47 PM
Except nothing is wrong with OEM wheels you ho. Here is a maxima with ES2s:
