Coolant drain/fill
Old Jun 27, 2014 | 09:57 AM
GNCMaxima's Avatar
Coolant drain/fill
Ive been doing a lot of research on how to properly flush your radiator... My question is if I don't have access to a water hose could I just do a drain/fill then repeat the process next month? The reason is to slowly get out all the old coolant by just using a drain/fill.
I only have 43000 miles but I drive 20k miles a year. Has anyone thought about doing their coolant this early? Btw I live in Texas so the heat can get bad at times.
EDIT* Also anyone know how many liters I need to refill? I cant find it in the Manuel
Old Jun 27, 2014 | 05:44 PM
GNCMaxima's Avatar
Anyone? I finally finished the flush but I had a lot of water coming from the middle of the car. I know some water is normal when running the A but this is over the top. Suggestions or any thoughts would be appreciated
Old Jun 29, 2014 | 06:08 AM
Wishbone's Avatar
The thing about running a garden hose through it is you are supposed to use distilled water. Tap water is not real good for your radiator. I change mine every 50,000 because like you the Oklahoma heat is a killer. You can get by doing a drain and fill every 50,000 because it should not be totally corroded. Now if you wait until 100,000 or later then I would do a flush. I would take it to a shop that has a machine that hooks up and flushes it out with distilled water.
Miket2006
Mar 1, 2021 03:55 AM
captchaos
Mar 15, 2016 12:18 PM
msellas
Sep 23, 2015 09:16 PM
junito1
Sep 23, 2015 12:14 PM
97_GXE
20
Sep 17, 2015 08:12 PM
