What is this pic? Transmission Drain Plug?
Old Aug 23, 2014 | 03:35 PM
Prophecy99's Avatar
drove 2-3 hrs to the shore and had a smooth ride thru backroads and highway , i then have a lot of trouble once i get off the highway and the car shifting. once I park i see fresh ATF all over on the ground and this pic
Old Aug 23, 2014 | 06:39 PM
Ghost_54's Avatar
Sure hope you have checked your ATF fluid level to be sure that you have not spilled it all out onto the ground.
Old Aug 23, 2014 | 07:01 PM
BigLou55's Avatar
Picture is pretty small it appears your drain plug is missing. you possibly caught it early enough to not cause major damage. The bigger question is where is your drain plug and how did it back ALL the way out.
Old Aug 23, 2014 | 08:02 PM
rich6661's Avatar
Did you have the trans recently serviced...at a quick change oil place like a Jiffy Lube?
Old Aug 25, 2014 | 06:14 AM
Prophecy99's Avatar
If I have the car at an average joe shop, do u think they could even provide me with help on a fix? In other words do I need OEM parts for the drain plug or anything like that?
Man this is so random
Old Aug 25, 2014 | 07:27 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Just go to your closes Nissan dealer or even a yunk yard and get the plug.... it will take you 5 minutes....
Old Aug 25, 2014 | 09:40 AM
rich6661's Avatar
It would be impossible at this point to prove anything so I'd do as Lontar1 suggest and go get a drain plug and refill the trans
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
markevans999
Sep 10, 2015 04:29 PM
I<3 A32's
Sep 10, 2015 11:07 AM
