7 Gen Rear brake strange issue
your brake pads have not seated or worn to match the rotor. I would suspect that the pad on that side is not flat ?.
The Nissan rotors will rust if you sneeze on them, but this surface flash rust will normally rub off with the very first application of the brakes. In your case, the rust is left because the pad is not wiping / rubbing against the rotor properly.
Have a closer look to see if the new pad is not seated properly or is otherwise damaged.
Huttig2009
Sep 25, 2015 03:31 PM
RealityCheck
Aug 5, 2015 06:18 AM
