Wheel and spacer question
Old Sep 30, 2014 | 03:19 PM
ibleedgreen's Avatar
So I've ordered a new set of 19x8.5 wheels with a 35mm offset. Running a 245-40-19. I'm dropping it on the Eibach Pro kit with the SPC camber arms and bolts.
I'm curious about running the spacers with this offset. I believe the oem 19s are 40mm? And I've seen the 20mm front and 25mm rear spacers pulling the look together nicely but that was on stock wheels. Any thoughts on if they will work fine?
Old Sep 30, 2014 | 06:36 PM
MaximaDrvr's Avatar
I personally would not use spacers on that setup.
Also, you are aware you will need longer studs, or the more expensive bolt on spacers, correct?
Old Sep 30, 2014 | 07:05 PM
dr_2010SV's Avatar
Stock is 50mm, so is you're going to run wheels with 35 offset you really don't need spacers, at least on the fronts.
Old Oct 1, 2014 | 04:24 AM
Absolutely.
I figured this as well. I've modded a few of my Crovettes and trucks but it never hurts to ask the forum. Most of you guys have already experienced it. This is just my wife's daily I'm spicing up a bit.
incubusjohnny
Nov 3, 2015 05:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
umnitza
Sep 1, 2015 01:03 PM
Maxboy23
Aug 11, 2015 11:59 AM
