Rear Door Water Leak
I have 2014 and have recently noticed water swishing back and forth in my rear driver door when it opens and close. It obviously shouldn't be doing this and I'm not sure how to correct the problem. Any suggestions would be greatly appreciated. Thanks
Sounds like a munufacturing screw up and drainage wasnt put in that door. I'd say check the other back door for drainage holes and see but being that new it should be going right back to the dealership it came from and demand the put in a new back door. Depending how long the water has been sitting im sure its probably developed atleast some rust whether it be even surface rust on the interior of the door which will spread.
^^ Well, looks like our 7th gen also has this problem.
Just noticed a bunch of water in bottom of rear driver side door, you can see water drain out from bottom if you shake the door.
Surprised to only find this one post on this...guess its not a widespread problem but clearly does happen. Ours is a 2014 sv
Gonna visit dealer I assume
So I looked at both doors, the bad one looks a bit different where the drain hole is.
Its like a manufacturing defect, the little hole on the bad door looks messed up. Anyway I moved the rubber around and bunch of water started to drain. It drained for a good 10 min and stopped, theres still a bunch of water in the door.
Looks like a dealer trip is not avoidable this time.
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
