NWP Engineering 75mm Big Bore Throttle Body Kit - 12hp GAIN!!
NWP Engineering.com
100% Plug and Play.
No tuning or portwork required. Perfectly port matched.
Features a tapered bore for increased airflow!
Works perfectly with our Thermal Intake Spacers!
8 HP Gain on the Maxima/Altima w/ stock intake manifold!
12 HP Gain on the Maxima/Altima w/ gutted intake manifold!
15+ HP Gain on the 350z/G35 w/ stock intake manifold!
Includes:
- NWP Engineering Throttle Body Adapter Plate Kit (Required to install 75mm Throttle Body)
Includes the following:
NWP Engineering Tapered Big Bore Throttle Body Adapter Plate (patent pending)
NWP Engineering Port Matched Throttle Body Gasket
4 Zinc Plated Self-Locking Adapter Plate bolts
4 Zinc Plated Throttle Body bolts w/ washers
Printed Detailed Installation Instructions with Photos (PDF Instructions)
Two Die Cut Silver Vinyl NWP Engineering Decals
- Brand new 75mm OEM Nissan Hitachi Electronic Drive-By-Wire Throttle Body
- NWP Engineering Plug & Play Adapter Wire Harness (Required to install 75mm Throttle Body)
Applications:
2003 - 2006 350z
2003 - 2007 G35 Coupe
2003 - 2006 G35 Sedan
2002 - 2008 Nissan Maxima (NWP Spacer Kit required on the 04-06 Maxima for EGR valve clearance)
2002 - 2006 Nissan Altima 3.5L (NWP Spacer Kit required on the 05-06 Altima for EGR valve clearance)
2002 - 2004 Infiniti I35
2003 - 2008 Infiniti FX35
2006 - 2008 Infiniti M35
2003 - 2007 Nissan Murano
2004 - 2009 Nissan Quest
NEW LOW PRICE!
$315 plus $15 shipping within the US.
($365 reg price)
We were recently able to reduce our costs on the 75mm Throttle Body units, so we are happy to pass these savings onto you! Thank you for your business!
You may place your order at: http://www.nwpengineering.com/Phenol...cers.html#BBTB
If you want to pay with a money order or are located outside the continental US, please contact me directly before ordering!
All packages will ship the same business day if received by 2pm EST. All packages within the US are shipped via insured USPS 2-3 day Priority Mail with Delivery and Signature Confimation
If you have ANY questions, please do not hesitate to contact me directly or post in this thread.
Thank you,
Aaron Kimball
NWP Engineering, Inc.
252-375-4NWP (4697)
[aaron@nwpengineering.com]
NWP Engineering.com
Please let me know if you have any more questions.
NWP Engineering.com
this is newbish, but does having a stock air intake kind of limit the purpose/effects of throttle body kit ?
I got the impression it compliments/give better results when you have upgraded the air intake
Thanks Aaron for your great company/products.
NWP Engineering.com
Our dyno tests showed a 8 HP gain on the 03 Maxima with the stock intake tubing and cone filter.
NWP Engineering.com
A gutted manifold is also known as an SSIM (Secret Sauce Intake Manifold) on the forums. This involves cutting the shelf out of the main chamber of the upper intake manifold and removing the VIAS assembly. This will still lose low end power and some midrange, but the gains in the top end are very noticeable. It's definitely a modification that is worthwhile if you are serious about increasing top end HP. An extended rev limiter is highly recommended if you want to get the full potential out of the SSIM.
We don't have a Big Bore Throttle Body Kit for the 95-99 Maxima, but we do have 2 products, both of which have been very popular. We have our Phenolic Thermal Intake Spacer Kit and our Engine Torque Link Bracing Kit.
You can check them out here:
http://www.nwpengineering.com/Phenol...rs.html#VQ30DE
http://www.nwpengineering.com/Phenol...tml#TorqueLink
NWP Engineering.com
But if you want to have the fastest acceleration possible, you will want top end HP even if it means losing a little low end. If that's the case, then you will like having our VIAS Block Plate or also doing the SSIM on top of that. Those mods will cause you to lose some low end, but the top end gains easily compensate for the loss and you will accelerate much faster than before from 0-60mph or in the 1/4 mile.
But since you want to keep your power below 4K rpm, then don't gut your intake manifold and keep your VIAS actuator in place and only have our 5pc Spacer Kit and 75mm Big Bore Throttle Body Kit installed.
NWP Engineering.com
Here is a link to that kit: http://www.nwpengineering.com/Phenol...rs.html#VQ35DE
And if you remove your VIAS actuator and install our VIAS Block Plate Kit, it will hurt low end power, but since you are removing an obstruction, it will help top end. You will gain approximately 5-8hp on midrange and top end power and your car will accelerate faster from 0-60mph and in the 1/4 mile.
Here is a link that kit: http://www.nwpengineering.com/Phenol...ers.html#VIASB
And we also have our Engine Torque Link Bracing Kit that will fit the 95-03 Maxima. This is not a modification that improves HP, but it will improve throttle response and keep your engine firmly in place on those days you want to drive aggressive.
And here is a link to this kit: http://www.nwpengineering.com/Phenol...tml#TorqueLink
NWP Engineering.com
Oh I understand. The more modifications you do, the more of a restriction that the stock 70mm TB will become and the more of a HP gain you can expect to see with our kit. But with the mods you listed for your 2002 Maxima, I would still expect around an 8hp gain by upgrading to our 75mm Big Bore Throttle Body Kit.
This is still on my list of things to do. I'd probably combine with the block off plate. Thanks for making such quality parts for our cars. Still using my spacer kit! Saving saving.....
NWP Engineering.com
If you already have our 5pc Spacer Kit, you will still need to purchase our full 75mm Big Bore Throttle Body Kit for $315 plus shipping. It will come with our 75mm Throttle Body, Adapter Plate, Adapter Wiring Harness, and bolts, gasket, and instructions.
Just mark "Yes" to the question on our website that asks if you have our 1/4" thick Phenolic TB Spacer installed. That way, you'll get the longer bolts for the 75mm Adapter Plate that will pass through your 1/4" Phenolic TB Spacer.
Thank you!
NWP Engineering.com
I'm sorry we don't have a Big Bore Throttle Body Kit for the 2001 Maxima. But we have a Phenolic Thermal Intake Spacer Kit and an Engine Torque Link Bracing Kit that will fit the 2001 Maxima if you don't already have them.
You may check them out here:
http://www.nwpengineering.com/Phenol...s.html#VQ30DEK
Thank you for the reply. I already have the Phenolic Thermal Intake spacer kit, but not the Engine Torque Link bracing kit, because the car will be S/C'd, does the Link can still be mounted ? If I recall correctly it has to be mounted where the Blower is...
Won't work with a supercharger unfortunately.
NWP Engineering.com
vingodine
45
May 21, 2016 12:46 PM
homewrecker
Aug 24, 2015 08:56 PM
