2 issues... stalling out in drive and rough idle???
Old Jun 13, 2015 | 04:28 AM
Jewing1978's Avatar
Learning a 98' Maxima is a different beast than my 74' BMW 2002 totally... So I fixed the fuel pump so it starts now. After running for a while the idle sits around 1000-800 rpms smooth. But when I give it gas it goes up to about 2k and is rough and struggles to go any higher?
Also when I take it out of P R or N its fine but when I put in any of the Drives
D 2 or 1 it stalls out. I have no clue.
I bought a knock sensor with new connection. Pain in the @$$ to get to. I have fat hands... I bought a VSS but have not installed yet. So I have no clue what the exact issue is... Anbody live in Jacksonville??? Thanks for your help guys.
Old Jun 15, 2015 | 08:58 PM
martyl45's Avatar
Any codes? Could be the MAF
Old Jun 16, 2015 | 10:33 AM
M in KC's Avatar
Sounds like the classic MAF or MAF/IATS. Check for codes but sometimes the MAF, if intermittently failing will not trip a DTC.
Old Jun 17, 2015 | 07:52 AM
cashoit's Avatar
Bad MAF
Old Jun 17, 2015 | 06:29 PM
kjlouis's Avatar
I asked the same thing with more info and hardly got replies. You guys hate me.
Old Jun 18, 2015 | 07:02 AM
Jewing1978's Avatar
Carbon or Charcoal?
So after taking the throttle body off, IACV off to clean. I found all this black stuff clogged all the air lines? What is this stuff? Is this carbon or charcoal from a type of filter in the EGR system?
Attached Thumbnails 2 issues... stalling out in drive and rough idle???-image1-1-.jpg   2 issues... stalling out in drive and rough idle???-image2.jpg
Old Jun 18, 2015 | 10:53 AM
asand1's Avatar
Carcoal canister is coming apart. there is a TSB. I havent replaced the canister yet, I did place a fuel liter in the evap line to stop the charcoal though. New canister is $30 on Rockauto.
http://www.aa1car.com/library/evap_n...ntb00-085a.pdf
Old Jun 18, 2015 | 12:02 PM
Jewing1978's Avatar
Do you guys think that the leaking Vapor canister would cause the car not to be drivable if the entire EGR system is clogged with charcoal?
Old Jun 18, 2015 | 12:33 PM
JoshG's Avatar
it would be a good idea to get all that carbon out of the EGR, Carbon in the car is no good.. it blocks air passage ways.
Old Jun 27, 2015 | 08:29 AM
Jewing1978's Avatar
Still EVAP issue?
So after I blew all the charcoal out of the lines from the leaky canister. I started the car with out the EVAP line and the car ran and I drove it with no stalling out. So after reconnecting the EVAP line the car now stalls when I put it in Reverse or Drive? Hmm I have no clue now? Any ideas? I am going to Harbor Freight to buy a ODB code reader... I am at wits end...
Old Jun 27, 2015 | 09:16 AM
JoshG's Avatar
has to be something with the EVAP that is causing your problem. the fact u said it drove the way it was supposed to without it, tells you something..
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
ballerchris510
Sep 10, 2015 09:35 PM
