Corner Lamp Removal
Corner Lamp Removal
i WAS TRYING TO REMOVE MY HEADLIGHTS, WHEN I PULLED THE SCREW THAT HOLDS THE HEADLIGHT AND CORNER LAMP TOGETHER, THE LAMP WAS STILL STUCK. IS THAT A PRESSURE FIT OR IS THERE A SCREW I AM OVERLOOKING TO TAKE THE CORNER LAMPS OUT?
THANKS
THANKS
You could try and search the forum, and not use all caps. Also there are 2 things that hold in the corner lamp. 1 is the screw you see when you pop open the hood. Second is a ball-socket joint that holds it in as well. Simply after you remove the first screw, get a flat headed screw driver stick in in the ball joint and twist it. It should pop the ball right out. Thats what I did to get it out.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
