AMSOIL Premium Coolant - Wholesale Pricing Available
Old Jun 27, 2015 | 10:25 AM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
AMSOIL has expanded their line of premium coolants and now offers three products to cover all applications:
AMSOIL Passenger Car/Light Truck Antifreeze & Coolant:
A pre-mixed Ethylene-Glycol coolant that provides superior heat transfer and excellent protection against corrosion, freezing and boil-over in Passenger car and light truck applications. It provides maximum protection in extreme temperatures and operating conditions, and provides superior protection for aluminum, steel, cast iron, copper, brass and solder alloys. Independent tests reveal AMSOIL Antifreeze/Coolant greatly surpasses standards for metallic corrosion and erosion, achieving nearly perfect scores in ASTM corrosion and erosion testing on cast aluminum cylinder heads, steel, copper, solder, brass and cast iron and aluminum water pumps.
AMSOIL Antifreeze/Coolant is a poly-organic acid formulation that does not contain inorganic acid salts (phosphate, nitrate, nitrite, silicate, borate, amine) found in conventional and hybrid organic acid (HOAT) antifreeze/coolants. AMSOIL Antifreeze/Coolant virtually eliminates scaling problems.
AMSOIL Antifreeze/Coolant is compatible with all ethylene and propylene antifreeze and coolant colors, as well as all plastics and elastomers (hoses, gaskets, etc.) found in cooling systems and carries a recommended change interval of 150,000 miles or five years, whichever comes first. http://www.amsoil.com/lit/databulletins/g3347.pdf
AMSOIL Propylene Glycol Low Toxicity Anti-freeze and Coolant:
Environmentally friendly Propylene-Glycol concentrated coolant that prevents corrosion on metal components. Independent tests reveal AMSOIL PG Coolant greatly surpasses standards for metallic corrosion and erosion, achieving nearly perfect scores in ASTM corrosion and erosion testing on cast aluminum cylinder heads, steel, copper, solder, brass and cast iron and aluminum water pumps.
AMSOIL PG Coolant provides extended service life in all gasoline and diesel vehicles, with recommended service intervals in passenger cars and light trucks of 150,000 miles or five years, whichever comes first, or 600,000 miles, 12,000 hours of operation or six years, whichever comes first, in heavy-duty and off-road applications. This product is a concentrate and should be mixed with distilled or other high quality water containing <100 ppm hardness. http://www.amsoil.com/lit/databulletins/g1156.pdf
AMSOIL Heavy Duty Coolant:
This Ethylene Glycol-based product is the ideal choice for mixed fleets of both passenger-vehicle and heavy-duty applications that want to use one antifreeze/coolant. This coolant is also free of phosphates, nitrates, nitrites, silicates, borates and amines) found in conventional and hybrid organic acid (HOAT) antifreeze/coolants.
AMSOIL Heavy-Duty Antifreeze & Coolant effectively protects cylinder liners against cavitation erosion/corrosion pitting, without the problems associated with nitrite and nitrite/molybdate technology.
AMSOIL Heavy-Duty Antifreeze & Coolant is a top-performing technology that performs extremely well in ASTM D7583 (John Deere Cavitation Test) testing and offers protection up to 600,000 miles, 12,000 hours or 6 years, whichever comes first in heavy duty applications or 150,000 miles or five years, whichever comes first in light-duty applications. http://www.amsoil.com/lit/databulletins/g3347.pdf
AMSOIL Coolants are premium products and are competitively priced. Please send PM or e-mail to lonestarlubes@gmail.com for pricing.
Wholesale pricing available!
Old Jul 4, 2015 | 05:09 PM
Please send PM or e-mail direct at lonestarlubes@gmail.com for quote.
Wholesale pricing available! No pressure, no gimmicks!
Old Jul 11, 2015 | 08:53 AM
Old Jul 25, 2015 | 06:32 PM
Old Jul 31, 2015 | 06:22 PM
Old Aug 8, 2015 | 12:08 PM
Old Aug 18, 2015 | 08:11 AM
Old Aug 21, 2015 | 02:50 PM
Old Sep 11, 2015 | 03:00 PM
Old Sep 18, 2015 | 02:26 PM
Old Sep 25, 2015 | 05:22 PM
Old Oct 9, 2015 | 01:55 PM
Old Oct 16, 2015 | 05:49 PM
Old Oct 21, 2015 | 08:24 AM
Old Oct 30, 2015 | 09:31 AM
Old Nov 7, 2015 | 08:21 AM
Premiere quality coolant that provides superior heat transfer and excellent protection against corrosion freezing and boil-over in passenger car and light truck applications. Contains no Silicates, phosphates, amines, nitrates, nitrites or borates...unlike other commercially available products, AMSOIL Coolant virtually eliminates scaling problems and is safe for water pump seals!
Full Time AMSOIL Certified Direct Jobber, 20+ yr Nissan owner, >12-yr org member, Maxima.org Sponsor & Donating Member, Veteran-owned business. Outstanding feedback with hundreds of satisfied customers throughout the US and Canada.
Wholesale pricing available on all products! No pressure, no gimmicks!
Old Nov 21, 2015 | 06:38 AM
Old Dec 2, 2015 | 05:37 PM
Old Dec 4, 2015 | 06:30 PM
Old Dec 12, 2015 | 07:13 AM
Old Dec 19, 2015 | 08:51 AM
Please send PM or e-mail direct at lonestarlubes@gmail.com for additional product information, recommendations and/or quote.
Old Jan 1, 2016 | 08:58 AM
Happy New Year!
This year, treat your vehicle(s) to a premium coolant! AMSOIL Antifreeze/Coolant is a poly-organic acid formulation that does not contain inorganic acid salts (phosphate, nitrate, nitrite, silicate, borate, amine) found in conventional and hybrid organic acid (HOAT) antifreeze/coolants.
Old Jan 9, 2016 | 12:01 PM
Old Jan 18, 2016 | 11:31 AM
Old Jan 23, 2016 | 12:00 PM
Old Jan 30, 2016 | 02:50 PM
Old Feb 6, 2016 | 06:46 AM
Old Feb 15, 2016 | 05:26 PM
Old Mar 7, 2016 | 11:11 AM
Wholesale pricing available! No pressure, BS or gimmicks!
Old Mar 14, 2016 | 02:49 PM
Old Mar 27, 2016 | 08:06 AM
Old Apr 1, 2016 | 07:11 PM
Old Apr 8, 2016 | 09:11 AM
Old Apr 15, 2016 | 03:07 PM
Old Apr 25, 2016 | 01:00 PM
Old May 29, 2016 | 08:00 AM
Independent tests reveal AMSOIL Antifreeze/Coolant greatly surpasses standards for metallic corrosion and erosion, achieving nearly perfect scores in ASTM corrosion and erosion testing on cast aluminum cylinder heads, steel, copper, solder, brass and cast iron and aluminum water pumps. Formulated to provide superior protection for 5-yrs/150,000 miles
Old Jun 13, 2016 | 02:10 PM
Old Jul 5, 2016 | 08:24 AM
Old Jul 16, 2016 | 06:02 AM
Old Jul 25, 2016 | 04:57 PM
