Strange/Random facts about the A32 Maxima
Old Jul 29, 2015 | 09:31 AM
dauntlessmax's Avatar
This thread is for anyone to post any random or strange facts the average 4th Gen Maxima driver wouldn't know about their car. Post on!
Old Jul 29, 2015 | 10:58 AM
dwapenyi's Avatar
The A32 4th gen weighs about 100 lbs less than the 3rd gen it replaced.
The legendary VQ motor was "born" in the A32.
Old Jul 29, 2015 | 01:14 PM
Finkle's Avatar
The third gen Maxima had a variable intake and variable valve timing
The fourth gen had neither
The fifth gen got the variable intake back
Old Jul 29, 2015 | 01:22 PM
lux97Max's Avatar
4th gen is equipped with forged rods, micro finished crankshaft and cams, Molly coated pistons, Its got chrome piston rings (Formula 1 technology) pretty good rod to stroke ratio, one of the best engines nissan built.
Old Jul 29, 2015 | 01:58 PM
Fakie J Farkerton's Avatar
The boost sensor has nothing to do with a turbo.
Old Jul 29, 2015 | 04:45 PM
NissanNismoZ's Avatar
By holding down your unlock button on your remote, you can roll down both front windows.
Old Jul 29, 2015 | 04:48 PM
Crusher103's Avatar
The front end will rust.....
Old Jul 29, 2015 | 10:22 PM
Finkle's Avatar
^^^ And the back, since through some infinite wisdom, Nissan decided to extend metal around both sides of the front and back wheel wells on the Maxima, but not the I30.
On a positive note, they are amazingly light for their size. My 97 SE with all options weights in at 3000lbs even.
Old Jul 30, 2015 | 04:24 AM
Turbobink's Avatar
At least some '99 SE-Ls manufactured after JAN 1999, were equipped with 5th Gen coolant overflow tanks.
Old Jul 30, 2015 | 04:25 AM
Turbobink's Avatar
That's not random or strange.
It's a standard feature.
Old Jul 30, 2015 | 06:22 AM
I'll add one.
Apparently the 4th gen's design was finalized in 1990, slated for a MY1993 release, but delayed and released in September of 1994. I saw this somewhere on the forum; correct me if I'm wrong anyone.
Old Jul 30, 2015 | 08:50 AM
Bobo's Avatar
The 1995 model was available before September 1994. I test drove a GXE in June. I ordered my 95SE, fully loaded, through an auto broker and picked it up on September 30th. I was supposed to receive it in August. Factory order. It was built in August. I live in British Columbia. I was told that delivery was delayed because given the currency relationships Nissan dragged their feet on delivering models into Canada that summer as they were making more money shipping them into the US at that time. Car and Driver had a review of the 95 models in their May or June magazine, which is what prompted my test drive and subsequent purchase.
Originally Posted by dauntlessmax
I'll add one.
Old Jul 30, 2015 | 08:53 AM
Bobo's Avatar
My 95SE, a Canadian model, is equipped with LSD, limited-slip differential. I understand LSD was not available at that time with US models. I am not sure when LSD became available in the US.
Old Jul 30, 2015 | 10:05 AM
dwapenyi's Avatar
In the US, no 4th gen maximas had it available OEM from factory. The VLSD was only available on the Infiniti I30ts, auto or 5-speed.....like mine
Old Jul 30, 2015 | 04:00 PM
Bonka's Avatar
Schnell kaputt
IIRC, the 4G was the largest vehicle in the Nissan/Infiniti lineup that used single piston calipers in the front
Old Jul 31, 2015 | 10:20 AM
asand1's Avatar
So when is an enterprising Canadian going to start pulling lsd 5 speeds and start exporting them?
Old Jul 31, 2015 | 12:21 PM
aackshun's Avatar
My 3/99 SE-L didn't have one... But who's the say any of the previous owners didn't put a 4th gen one in it's place.
And it's a weird car.
Digi AC
Standard Tranny
Black Leather
but no ABS.....
But that sunroof tho...... (As I understand, this and Bose are about the only standard options on SE-L's)
When the 5 speeds are worth more than their weight in salt.
Old Jul 31, 2015 | 02:31 PM
Turbobink's Avatar
This e-compartment has never been owned by anyone but me and never been in an accident ... I assure you.
This is the original overflow tank.
Old Aug 8, 2015 | 10:14 PM
jump_and_drop's Avatar
There was a variant of the 4th gen Maxima sold in Korea until 2005 as the Renault Samsung SM5. Strange name for a car and hard to imagine a Samsung car, but they basically own South Korea.
Old Aug 9, 2015 | 01:46 AM
dwapenyi's Avatar
When you bought your car, was it a special order?
Old Aug 9, 2015 | 04:42 AM
Turbobink's Avatar
If it was special ordered, it wasn't by me.
This car was sitting in the showroom and I bought it, literally, off the show room floor.
Old Aug 9, 2015 | 11:27 AM
asand1's Avatar
The 1995 maxima has obdII, even though the port is not in the mandated area. Most shops will argue that the 95 is only obdI.
Old Aug 9, 2015 | 12:07 PM
criminalslang810's Avatar
They tend to burn oil on a high mileage engine, you may not have no leaks present, but the oil is gone....i heard of many reason, but just check you oil weekly or every 3 day..
Some say bad cat, but if you know many new nissans have this problem , some say the stock cat breaks down over time little particles get sucked into the cylinders which scare the cylinder walls.. who knows?
And timing chain jumping a tooth, thats what happen to mind of timing a bit bad starts....
Old Aug 9, 2015 | 01:17 PM
asand1's Avatar
Lol I have 315K and burn no oil. The VQ30 does not suffer this problem, the VQ35 on the 5.5 gen does.
Old Aug 9, 2015 | 01:43 PM
Turbobink's Avatar
They tend to burn oil on a high mileage engine, you may not have no leaks present, but the oil is gone....i heard of many reason, but just check you oil weekly or every 3 day.. Some say bad cat, but if you know many new nissans have this problem , some say the stock cat breaks down over time little particles get sucked into the cylinders which scare the cylinder walls.. who knows? And timing chain jumping a tooth, thats what happen to mind of timing a bit bad starts....
This is just wrong and these are certainly not oddities common to the 4th Gen.
These issues are, however, indicative of a 4th Gen that is/has been neglected.
Old Aug 10, 2015 | 02:42 AM
dwapenyi's Avatar
Just to re-iterate what others have said, the 4th gen VQ30DE and the 2000-01 VQ30DE-K, are bullet proof. Take care of it, and it will take care of you, for a looooong time. Even a somehwat neglected VQ30 will still run forever.
If you come across a 4th gen that is drinking oil, skipped a tooth etc, it was probably severely neglected, as in never changed the oil, or changed it every 2 years after 50K miles or some such nonsense.
Old Aug 10, 2015 | 04:45 AM
You guys are right, but i am from the city parts of nj, and i am going by what i have seen,. Yes far more clean red top 3.5 having heavy oil consumption.....i still think the 96 maxima was the best built in my opinion .. These guys above me in this thread are correct 100%, just going buy the ones i physically seen and chatted with the owners in the city where people beat on there rides... Just gas and water not even antifreeze.....
Old Aug 22, 2015 | 04:16 AM
dwapenyi's Avatar
All 4th gens came with an RSB built into the multi-link beam suspension.
Old Aug 22, 2015 | 06:40 AM
aackshun's Avatar
Lease car if that helps.
Doesn't have any evidence of being in a wreck thoughhhh.
I mean TBH, if it's a 5th gen overflow that came on SE-L's it prolly broke and one of the previous owners replaced it with a 4th gen one, since they DON'T suck.
Back on topic.
My '99 SE-L Tipped the scales @ 2700
While my fully loaded '96 SE hit 3010
No explanation on the weight discrepancy.
Both cars literally had the same mods... Like not as in the same kind, like as in I removed parts from one and put it on the other....
Old Aug 22, 2015 | 07:38 AM
Turbobink's Avatar
I mean TBH, if it's a 5th gen overflow that came on SE-L's it prolly broke and one of the previous owners replaced it with a 4th gen one, since they DON'T suck....
Nope.
I purchased this car in MAR of 1999 off the dealer's display floor.
It had 12.2 miles on it when I was handed the keys ...
Speculate away but no one has ever owned, leased, rented and, for the most part, driven this car but me since it was brand new.
Did I mention that it had 12 miles on it when I bought it?
Old Aug 22, 2015 | 07:42 AM
aackshun's Avatar
Nope.
Noooo, I'm saying MINE was a lease car for the first 90k of it's life. Then owned by some guy, then owned by some guy then me from 150k and so on.
Old Aug 22, 2015 | 08:08 AM
Turbobink's Avatar
I gotcha ... Sorry ... my misunderstanding.
Old Aug 23, 2015 | 03:38 AM
bumpypickle's Avatar
Northern Maximas cannot be obtained without rust
Old Aug 25, 2015 | 06:57 AM
Krumpwave's Avatar
The engine
The engine shouldn't suck any particles in from the exhaust. If it were to suck from the exhaust this indicates issues in the valve train have your vales adjusted. Good tip when buying a used car( like a maxima) put a piece of paper over the exhaust tip. The paper should be constantly be pushed away. If it alternates being sucked in and pushed out, the vehicle has valve issues.
Old Aug 25, 2015 | 07:23 AM
martyl45's Avatar
Rare exception as the only rust I had was on the muffler on mine, 60086 miles so far. body is rust free
Old Aug 25, 2015 | 07:39 AM
dwapenyi's Avatar
1st, this is a A33/VQ35 issue, not a A32/VQ30 issue. That gripe doesn't belong here. Secondly, I wouldn't entirely blame Nissan as I have seen it happen in other manufacturer's vehicles, like the 2007 Toyota MR2 spyder. Not only that, but the 2004 and later VQ35s dont seem to suffer from this issue as much. It seems that The US and other countries that are trying to cleanup vehicle emissions have forced automakers to shove the pre-cats so far up the exhaust, that the risk of suck-back went up considerably.
All this to make that 10 minute warmup exhaust more environmentally friendly. Once a vehicle has reached operating tempurature, pre-cats are useless, and are only a blockage in the exhaust system.
Old Aug 28, 2015 | 08:03 PM
stromm's Avatar
I'll add one.
The stickers show my Maxima was built 08/94. My father bought it the last week of 08/94 as a birthday gift to himself.
Old Aug 29, 2015 | 05:30 PM
Junebug1701's Avatar
Congrats! Your Max is now of legal age! Mine will turn 19 in a couple of months.
schmellyfart
Sep 25, 2015 04:47 PM
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
