Radiator fans
Old Aug 22, 2015 | 11:25 AM
jerrod99_se-l's Avatar
Radiator fans
Noticed car heating up yesterday...got to poking around a little and found both fusible links blown...looked a little further and noticed melted wires coming out of fan motor...motor locked up completely...wires melted all the way to the plug! Trip to pull a part...complete fan assembly $20...spliced in new plug installed fan motor and fuses and all is good! Easy job!
Old Aug 22, 2015 | 12:49 PM
lux97Max's Avatar
Radiator fans
Getting to know your car is priceless! Good job man!
Old Aug 22, 2015 | 08:03 PM
Thank you sir!
Old Aug 23, 2015 | 02:28 PM
Carlos Levy's Avatar
hi, i am new here and just got a 99 A32. can someone help me answering if a radiator fan for a 2001 maxima fits my car?
thanks for your help
Old Aug 23, 2015 | 04:02 PM
From what I can see the shrouds is different for sure...but I'm pretty sure the motor is the same...just swap the motors
Old Aug 23, 2015 | 05:13 PM
DennisMik's Avatar
The actual fan is the same but the connectors are wired differently. You have to swap wires.
And please, only post one problem in one thread, not multiple threads.
Old Aug 23, 2015 | 09:21 PM
Low speed side
I may have been a little fast in saying they work again...a/c on...they work fine....a/c off they won't come on...fuses/relays are good...both fans do work...CTS possibly? Code scanner shows temp at 214...fans should have came on right?
Old Aug 23, 2015 | 11:57 PM
ef9's Avatar
ef9
The fans should operate on low speed between 207deg and 220deg.
Above 221deg, the fans should operate on high speed.
Old Aug 24, 2015 | 12:03 AM
ef9's Avatar
ef9
Do you know if the fan shroud/assembly will swap over too?
I verified exactly what you said, and you're 100% correct that the wiring is swapped between the A33 and A32.
Old Aug 24, 2015 | 08:58 AM
Update! Pulled rad fan relay 1...melted post...replaced and bam! Fans work...
Old Aug 24, 2015 | 10:10 AM
DennisMik's Avatar
Excellent troubleshooting. Happy driving.
Old Aug 24, 2015 | 10:24 AM
DennisMik's Avatar
This is true for only the 1996 Maxima and i30.
All others 203º to 221º F for the low speed range
Maxima - 95, 97, 98, 99, 2000, 01, 02, 03 plus
i30 - 97, 98, 99, 2000, 01
i35 - 2002, 30, 04
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
RWCreative
Sep 21, 2015 11:01 AM
