What is purpose of that small dot at middle of rear brake pads?
Old Sep 8, 2015 | 01:45 AM
bbsitum's Avatar
It is necessary to align hole in rear caliper cylinder with that circle at pad to be capable install caliper. It is possible see in picture that cylinder catch circle at pad.
http://www.shiftice.com/images/brake...IMG_5200-1.jpg
Old Sep 8, 2015 | 07:01 AM
RealityCheck's Avatar
Took a dremel to grind it off. I saw one day it wasn't aligned with the piston and it's a pain in the *** to turn it.
Old Sep 8, 2015 | 07:39 AM
njmaxseltd's Avatar
When you screw the caliper piston back it, make sure the indents are indexed up/down/left/right. Then the nub on the back of the brake pad sits in the upward index spot on the piston.
Old Sep 10, 2015 | 10:54 PM
Finkle's Avatar
I also ground mine off. My impression of it was, it was preventing the brake piston from turning as the pad wore down. My rear brakes developed play between the pad and piston.
Old Sep 11, 2015 | 04:55 PM
Rit's Avatar
Rit
It is for the emergency brake to operate correctly ob the rear brake pads. Make sure it sits in the correct position in the brake pads. It is set by rotating the piston with a special tool, or needle nose pliers.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
