problems with 95 max! please help
Old Sep 8, 2015 | 05:12 PM
bryants95max's Avatar
I was wanting to check the trans drop resistor with an ohm meter and I was wondering how to do that?
And I have 8 codes
P0325
P0180
P1441
P0105
P0443
P0446
P1105
And the o/d light flashes 17 times when car is first turned on. The trouble I am having is that the car will rev up to only 2500rpm sometimes but it shifts hard and won't really go above 4000rpm no matter how much throttle you give it. It also idles at 700 until you drive it a little. Then it idles at 900-1000 and it can tell it's too much when you bucks when you put it in drive. Thanks for any help!!!!!! Here's my video on YouTube https://youtu.be/6pVWygy8WiU
Old Sep 9, 2015 | 06:41 AM
kjlouis's Avatar
Time for an overhaul... Map sensor, absolute manifold pressure sensor(is on idle air control valve right?) Is probably a good chunk of it. After that I would go for egr, and evap systems. I'm not familiar with how fuel temp sensor effects performance.
Old Sep 9, 2015 | 07:17 AM
Im gonna dump the "charcoal canister" by the fuel tank and clean the purge valve and hoses if I can figure out where and how. Can anyway help me out with this. Thanks kjlouis
Old Sep 10, 2015 | 02:02 PM
JvG's Avatar
JvG
Youtube has good instructions to fix your issue. Also do a search in this forum.
Most of us do not know the codes by heart. If you would also say what the code says, you might get more help. I mean something like this: 0325 - knock sensor.
Old Sep 10, 2015 | 07:05 PM
0325 knock sensor
1441 evap emission control system small leak
0180 fuel temp sensor "A" circuit malfunction
0105 MAP circuit malfunction
0443 Evap purge valve
0446 EVAP canister vent control valve
1105 MAP/BARO pressure switch solenoid valve
Old Sep 10, 2015 | 07:08 PM
I checked what I believe is the trans drop resistor and I got 12.6 ohms I think. Broke my heart. I was hoping to see something way below 12
Old Oct 1, 2015 | 08:12 AM
update
Still have the shifting problem and would really apprectiate some help. I was gonna dump the charcoal canister, crawled under there and looked and did not see it. Noticed under the hood there was 2 or 4 holes where some EVAP equipment belonged. the whole evap system has been removed so I guess I don't need to worry about those evap related codes. please please please help lol
Old Oct 2, 2015 | 01:19 AM
max ride 41's Avatar
so your name's brian and you have a 95?? hmmmm, me too!!! man, and i thought my 95 was messed up, compared to you i have a like new car!! what color is it??? if you say dark blue then i'm going to be needing to see some pics!!! i haven't seen a list like that since i went grocery shopping earlier this week. gl
Old Oct 2, 2015 | 07:11 AM
My last name is Bryant and mine is green. And the last three codes can be thrown out because they are evap related and they removed the entire evap system
Old Oct 2, 2015 | 12:35 PM
JvG's Avatar
JvG
The charcoal canister and other parts live by the gas tank, on the left side of the car.
Old Oct 2, 2015 | 12:52 PM
It doesn't have charcoal canister and stuff
matts95max
Apr 23, 2025 10:44 AM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
