no power at all
Old Jan 21, 2016 | 04:31 AM
tclark4life's Avatar
no power at all
Just drove my car to work and came out to leave it wouldn't start there is no power at all no headlights, interior lights and no crank at all. Has a new battery connections are tight, full tank of gas starter is new. What could be the problem?
Old Jan 21, 2016 | 05:34 AM
theWalkinator's Avatar
Alternator perhaps, did you left your headlights on? Jump start the car, measure the voltage, should be around 14.5v, or your alternator is bad.
Old Jan 21, 2016 | 10:03 AM
DennisMik's Avatar
There is a main fuse attached to the positive battery connection. It is 140 amps. If this has blown, it's almost the same as disconnecting the battery cable. If this fuse is blown, there is a serious problem somewhere.
Old Jan 21, 2016 | 07:03 PM
A bad alternator won't prevent a car from starting, it will prevent it from running.
As stated, maybe you left something on and it drained your new battery?
Check fuses, wiggle your battery connections, check grounds
Old Jan 22, 2016 | 07:42 AM
asand1's Avatar
A bad alternator can have a shorted diode that drains the battery while not running. Also a bad alternator will not charge the battery, allowing it to drive that last time and then be parked, unable to start again.
Old Jan 22, 2016 | 12:54 PM
JvG's Avatar
JvG
Have someone attach jumper cables to your battery.
Don't start it yet. Do the headlights work? The wipers? Other things?
Next, start your car.
If you are able to run the accessories, you have a good main fuse.
If the car starts, great.
Then your problem would be a discharged battery.
Yes, I have seen a bad diode in the alternator cause this.
Old Jan 22, 2016 | 03:23 PM
Thank you Captain Obvious
bigmike249
Dec 11, 2015 02:00 PM
dealsgap
18
Dec 1, 2015 10:10 PM
kmitchel
Nov 13, 2015 06:37 AM
trimmer
Nov 8, 2015 06:00 AM
Dieseldan
Nov 6, 2015 10:38 AM
