Mevi manifold
The MEVI manifold itself is Plug N Play. the only thing you may need a vacuum line reducer or "T" adapter, depending on how your Throttle Body is. Once you go install it, you'll see what I mean.
Not mandatory, but it's recommended you change the Throttle Body gasket, EGR gasket, IACV gasket, and Upper to Lower Manifold gasket when doing the swap.
Don't forget, you need a way to activate it so it opens at the proper RPM.
Old school way is Harlan RPM switch (if the guy will respond to you...good luck) or Summit RPM switch
New school way is VAFCII or Emanage Ultimate
You'll also need a vacuum canister with built in check valve and a vacuum solenoid.
See link
http://www.vqpower.com/v3/content/mi...intake-install
The written instructions are pretty solid, but the diagrams and discussion relating to the electronics/activation of it are pretty crappy.
I have a good (and very simple) wiring and vacuum diagram I made (if I can find it) that I cans share.
See link
Harlan isn't junk IMO. Although I know you and Neal hate them because you've had bad luck with them. 3 of my Maximas have MEVI's with Harlans and have had no isssues for like 6 years now. I installed Ptatohed's MEVI with a Harlan...no issues. And one more on another friend's Max...no issues.
The_Fixer
Feb 4, 2016 07:58 AM
DeusExMaxima
Jan 29, 2016 12:36 AM
