Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Replace Full Wheel Hub assembly or just berring.
Old Feb 14, 2016 | 02:04 AM
ColdCananda's Avatar
Hello I have a 2005 nissan altima: I've been driving on a sticking rear caliper for about 5,000KM's before I actually noticed today, From my quick inspection today I'm thinking it just sticking slide pins and I wont have to change the calipers, however with the heat that has generated I think the wheel hub bearing must of seized (I'm going to see if vibration continues after I replace slider pins tomorrow. My question here today is since I don't have a press for the push bearing should I just spend the extra $50.00 and replace the whole wheel hub assembly? I's it fairly easy and is it better than just changing a bearing?
Thanks guys!
Old Mar 6, 2016 | 06:11 PM
asand1's Avatar
Thanks guys!
There is no "assembly" available, as the Maximas do not use a unit bearing. The bearing must be pressed into the knuckle, then the hub pressed into the bearing.
Old Mar 6, 2016 | 09:51 PM
Brudface's Avatar
He's talking about the rear.
To the OP, the rear is SUPER easy to replace with the whole assembly. I wouldn't even bother with a new bearing and pressing it on. I don't know where you are in Canada but usually local napa's carry that stuff or they can at least order it in.
Old Mar 7, 2016 | 09:30 PM
george__'s Avatar
Put in some poly mounts in there!!!!
Old Apr 15, 2016 | 01:13 AM
asand1's Avatar
My bad. AFAIK the rear wheel bearing is NLA, and the whole hub is necessary.
Derrick2k2SE
46
Nov 16, 2016 07:17 PM
a1gio2
Jan 17, 2016 05:49 AM
Lowered_a33
Jan 15, 2016 07:13 AM
Lowered_a33
Jan 15, 2016 04:55 AM
