unidentified bracket
Old May 21, 2016 | 07:50 AM
zunk's Avatar
Can anyone tell me what this bracket is and where it goes?
Old May 21, 2016 | 04:06 PM
Derrick2k2SE's Avatar
I'm not sure but it looks like it bolted on and had part of the wiring harness clipped to it.
Nissan uses a lot of brackets to hold the wiring in place. Most of them are unnecessary. I have a box of them I've removed and replaced with zip ties.
Old May 22, 2016 | 08:03 AM
zunk's Avatar
It for sure bolted on. It's pretty heavy, so I think it's important. I just don't know where. Just finished head gaskets after long time of being torn down. This was left over.
Old May 22, 2016 | 11:36 AM
Take a look at the side with the four holes. It's hard to tell from the pic but I don't any marks from bolt heads or any wear pattern from being bolted to something rigid. That tells me it probably had some of those push through wiring/hose clips attached to it. Some of the wiring brackets they use are very overbuilt.
Old May 22, 2016 | 02:35 PM
Chorca's Avatar
Goes on the back of the engine, near the timing cover, right there.
larger photo here: http://imgur.com/PyjtsDF
Old May 22, 2016 | 02:42 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Yeah, if it has small holes, then it likely holds O2 sensor wires
Old May 22, 2016 | 02:45 PM
Chorca's Avatar
On this '05 engine, the oil pressure switch is hooked into the top hole, bottom one might be o2, yeah.
Old May 22, 2016 | 04:20 PM
zunk's Avatar
Thanks Chorca
