need a new rad, steel or standard?
Old Dec 3, 2016 | 04:33 PM
max ride 41's Avatar
well, i tried some epoxy on the radiator and it didn't hold 2 weeks. so, next thing is replacement and i thought of maybe doing a solid steel one instead of a standard. opinions matter, but i want something that's going to hold up and isn't super expensive. advantages, disadvantages to steel and what brands of rads on the interwebs are a decent part. thanks
Old Dec 3, 2016 | 05:41 PM
CS_AR's Avatar
If I had to buy one tomorrow for the GLE automatic, I think I would get an OSC from Rockauto.com for roughly $85.
You want to avoid any radiators with steel parts -- especially in an area where rust is likely.
I've seen several Honda owners loose their transmissions to the Strawberry Milkshake of Death (SMOD) where the radiator coolant mixes with transmission fluid due to steel washers on the transmission fluid coolant fittings.
OSC Radiator Video
Old Dec 3, 2016 | 06:45 PM
the osc does not come with a new radiator cap on it. my rad cap is the original from 1995 i believe that i had swapped over from the original rad. place to get a new one? oem?
Old Dec 3, 2016 | 08:00 PM
CS_AR's Avatar
OEM. I only use OEM radiator caps and thermostats.
Old Dec 4, 2016 | 12:00 PM
i meant aluminum, not steel. and, i found the same osc rad on ebay cheaper and free shipping but with only a 30 warranty? if i go with a store brand like car quest i get a limited lifetime warranty? do i just get a advanced auto one and say screw it cause of the warranty?
Old Dec 4, 2016 | 12:45 PM
Zerodrag's Avatar
I went with a direct replacement Koyo radiator. They aren't very expensive online. For stock applications, I would just go with a direct OEM replacement rather than anything "performance".
Old Dec 4, 2016 | 01:17 PM
i looked at koyo, not rated as well as the osc but has a better warranty.
Old Dec 4, 2016 | 07:23 PM
skywalker85's Avatar
I replaced mine about 2 months ago.. Picked it up off eBay for $36.. Looks well built and solid.. Install was very easy..
Here's the link..
https://www.ebay.com/itm/291818643922
Old Dec 4, 2016 | 07:25 PM
DennisMik's Avatar
I put a Koyo radiator in my 94, 97 and 2000 Maximas and didn't have any problems with them.
I would suggest that you replace the rubber support grommets on the bottom and top of the radiator. You need 2 each.
top grommet - 21506-51E00 msrp $3.60 each
bottom grommet - 21507-1E400 msrp $12.55
Old Dec 4, 2016 | 07:53 PM
For you, I say just get the cheapest one you can get your hands on...forget the all aluminum
and lots of discussion in your first thread.
https://maxima.org/forums/4th-genera...edges-top.html
Old Dec 5, 2016 | 03:36 PM
JoshG's Avatar
Honestly, A good decent radiator will do fine. I bought not a cheap one but not an expensive radiator over a year ago, and no problems at all..
Old Dec 5, 2016 | 04:05 PM
CS_AR's Avatar
Here's the link..
Now there's a deal.
Old Dec 5, 2016 | 04:08 PM
JvG's Avatar
JvG
I bought a koyorad a few years ago. It was good qualty, and I am happy.
Sick the radistor is a critical part, I chose NOT to use the cheapest option.
Old Dec 5, 2016 | 04:16 PM
well, i went with an osc as cs-ar recommended, got it off of ebay for under 70.00. here it is, limited lifetime warranty..
http://www.ebay.com/itm/Radiator-OSC...RYCcWO&vxp=mtr
anything besides hoses and clamps to check while the rads out?
Old Dec 5, 2016 | 05:42 PM
CS_AR's Avatar
How old is your thermostat?
Unless someone can prove otherwise, I bet this is the identical radiator. Same part number and all.... MTC...OSC...same ****
http://www.ebay.com/itm/RADIATOR-FIT...NXiYyF&vxp=mtr
Old Dec 5, 2016 | 05:49 PM
nope, stole that pic off of the interwebs, plus mine is guaranteed original. not to say that some of these unheard of names aren't any good. plus, that ones only got a 1 year warranty.
Old Dec 5, 2016 | 05:59 PM
LOL. You ain't getting an OEM original for $70 if that's what you're eluding to...
From your own listing...
Warranty Duration: 3 months
Warranty Type: Manufacturer Warranty
Old Dec 5, 2016 | 06:32 PM
incorrect sir, talked to the owner of said company on the phone and he guaranteed me a lifetime warranty. apples to oranges anyway, stuff nowadays is made so well compared to a few years ago. i went with that rad after watching a video comparison and seemed legit to me.
Old Dec 5, 2016 | 06:42 PM
I recommend you replace the hoses coming off the radiator and into the transmission.. Clamps too!
About 16inches should do you good..
Old Dec 5, 2016 | 07:08 PM
CS_AR's Avatar
Always good preventative maintenance.
Old Dec 5, 2016 | 07:28 PM
I'd be very surprised if you truly got a lifetime warranty on a radiator. You should get a warranty card with your radiator. Post it up for all to see.
I scoured their website for the past 15 minutes. I even watched their youtube videos... They go on and on about how great their radiators are, make comparisons and show pictures between their radiator and the competitors, but no where does it state lifetime warranty on their website that I could find. If you find it, let us know.
http://oscautomotive.com/products/
Old Dec 5, 2016 | 10:20 PM
DennisMik's Avatar
Forgive me for repeating myself.
Old Dec 5, 2016 | 11:46 PM
i saw your response dennis, i was thinking do i need to replace thermostat or anything else that normally isn't replaced whilst replacing all the rubber and clamps. btw, i replaced the lower trans line and upper grommets twice cause i look under the hood constantly.
Old Dec 6, 2016 | 02:31 AM
asand1's Avatar
I will add that Koyo has been great to me. Installed 4 years ago and paid less than $100.
Old Dec 10, 2016 | 06:29 PM
got the new osc radiator and i'm not impressed. the new oem rad cap sits weird on it and the box was damaged so i'm probably going to send it back as there was damage to the rad as a result.
Old Dec 10, 2016 | 06:59 PM
maximaxi's Avatar
My choice would be Denso
A Denso radiator with an OEM cap, and spray some Krown on the radiator support!
Old Dec 10, 2016 | 11:46 PM
Waiting for pics of said lifetime warranty card....
Old Dec 11, 2016 | 01:40 AM
no card, owner said that there would be a lifetime warranty from osc. here's the new oem rad cap that sits sideways. and damage to the "new" radiator.
bends to the front and rear and this ones going back
Old Dec 11, 2016 | 06:44 AM
jholley's Avatar
The ATF hoses are labelled 'Transmission Oil Cooler'. I cannot recall the combined length of both the feeding and return hoses but they total to more than 16". I purchased 3 feet of that 5/16" hose along with SS hose clamps at Advance Auto.
Old Dec 11, 2016 | 03:45 PM
question, i replaced the drivers side coolant line with an oem one 2 years ago, can i just use pressurized 5/16 hose instead of the molded oem one for the other one? clamps i got, i guess i play it by ear on those rubber feet on the bottom. also, one of the connectors that hold the fans to the rad broke. any way to fix/rig that up so it holds in place?
Old Dec 12, 2016 | 06:50 AM
jholley's Avatar
Are you referring to the upper and lower coolant hoses connected from RAD to engine block or the transmission cooler hoses connected from the RAD to the AT? If it's the transmission cooler hoses then you can buy them at almost any auto store that carries them. As stated earlier I got 3' of the 5/16" hose at advanceauto. You don't need OEM hoses for those. They're not double braided like the fuel injection hoses so they bend easily onto their plastic mount clips.
Old Dec 12, 2016 | 01:13 PM
thanks, new rads in, new fluid, no more leaks checked everything we could to make sure all was good. did the tranny mount as well and plugged passenger tire up. doing another motor mound and one of these...
http://www.ebay.com/itm/141836986334?ul_noapp=true and i should be good, ( i hope )
Old Dec 12, 2016 | 05:45 PM
CS_AR's Avatar
Nice job B!
I just ordered one to keep in the workshop. I think I paid $30 something a few weeks ago to replace the one on the 98. I do keep spares but they aren't too flexible.
Old Dec 12, 2016 | 07:47 PM
So what radiator did you put in?
