Supercharged Maximas w/ BOV
Ok I got the Blitz DD and it sounds kinda weird, but it's not annoying like the Greddy. I like the sound the Greddy makes but the constant hissing during decelleration is kind of annoying. Does anyone else have any recommendations for maybe a BOV that's a little nicer when shifting, but not annoying like the Greddy?
Thanks!
Thanks!
Re: Supercharged Maximas w/ BOV
Thanks!
Thanks!
I don't know if this will help you guys since SC boost is dependent more on RPM than throttle (correct me if I'm wrong), but drilling a bleeder port may help make the BOV less sensitive; i.e.- keep it from activating as often.
High Boost BOV mod
Hope this helps
High Boost BOV mod
Hope this helps
we dont boost high enough pressure to require a bleeder port
its just the setting on the BOV needs to be tighter..
brian can also adjust the spring and get the "high" performance spring so that its harder to blow off.
High Boost BOV mod
Hope this helps
High Boost BOV mod
Hope this helps
Nah my car rules, I'm keeping it.
When are you taking it to the track? You already got a great time running NA. However, with a SC, it's a whole new game. I'm sure you'll get it down in time if not already.
main purpose of having the BOV is so that your turbine doesn't have a blow back and get damaged from internal pressure. not really for the whizzing sound . but thats just the kicks
how i do it is i rev to 3k and let off and thats how i measure the amount of blow off i would like to hear.
--ches
--ches
if you open the hood and stick your ear next to it.. its loud. heheeh
pitty other people on the street can't hear it as loud.. #%@ doh
Yeah Cheston I want to hear about this adjustment thing???
I'm going to try out Cheston's suggestion to bring it up to 3k rpm and let off to hear the sound as I fiddle with the setting.
Huh? You talking to me? My fastest NA run was a 15.4, he's a lot faster than me.
Originally posted by OgreDave
i have the loudest whiny noise
throw steve kim in the car tho.. dunno which would be louder, the v1 or him..
Dave, you still got the 3.48 pulley? Time for a smaller pulley, come on, you know you want it.
Oops I thought you meant the one on the top, top, now I see what you mean, well I set it to the tightest and loosest and couldn't tell a difference, but I hardly drove it. Which way is supposed to be the loudest/longest/etc?
BlkCat sorry, usually I'm quick to understand mechanical things, but I have no idea what you want me to do, any further explanation would be greatly appreciated.
Here's a pic I found...
http://store5.yimg.com/I/supra_1673_54022680
Ok, you see that threaded bolt sticking up on top of the bov? At the top of it an Allen key is able to fit in. So once you loosen the nut that holds it in position you use the Allen key to raise or lower that bolt.
Now some people have loosened it so that it is almost hanging on by a few threads but I found the noise to get a bit annoying while doing every-day type driving. I moved mine to half-way so that it'll make some noise when you're in enthusiastic mode
I get a nice burble when I drive normal around town. When I stomp the pedal and let off the bov gives off a "Phhhhtt-***-***-***" kind of sound. Daniel
I figured it out, thanks. It seems that the thing is the loudest and longest when I leave as much thread visible as possible (or just take the entire thing out). Is this consistent with your observations?
the bov is loudest when open. i.e. more air flowing thru the chambler to make it whistle.
so the more you open it. the louder it gets. BUT that means you wont have enuf pressure in the system when say you wanna stomp on it...
if its closed, you'll get better boost response, but not as loud.
hope that helps.
also. i've notice when i stomp on the gas in first after moving from a stop.. the boost pressure is not at 0. its at 10 vaccuum. why? because the BOV is open too much, and in first gear you're just pushing too much air into the car than it can handle...
so. my suggestion is if you stomp on it in 2nd gear, and you're still vacuuming, then close the bov some.
--ches
hope that helps.
--ches
remember!
sleeper mean no noise. heheh
but pitty with the aux fuel pump and all. we can't sneak up on unsuspecting mustang gts or what not. bah
Oh thanks Cheston, yeah it seemed like my car doesn't have the punch it used to have. It all makes sense to me now. I'm going to go close it a bit.
..ill get on your level sooner or later with alot of overtime and top ramen dinners...lol..you coming down this sunday??
