SRS Bin File for 95 Nissan Maxima
Does anyone know where I can get a clean copy of a 95 Nissan Maxima srs bin file? I'm trying to use it to clear the code from my airbag module.
Part No. 28556 41U00
There are some modules for sale by searching for Nissan 28556 41U00.
http://www.fs1inc.com/air-bag-contro...41u00-oem.html
https://www.amazon.com/28556-41U00-N.../dp/B00KTIEUX6
If you buy a used one, I doubt the seller will know what the history log contains. It takes Nissan Consult or NDS1 to read the log.
When I bought airbags and SRSCU from another I30, it all worked and I was able to clear up my SRS light problem. However, the SRSCU log was not clean and there were some codes in the log from an incident that had occurred with that car in the past.
Unless you buy a new OEM replacement, you will inherit any code that may have occurred in the donor car's past.
Here's the log from a working SRSCU that I purchased from a salvege yard I30 to remedy my code problem after a deployment.
Note the message that past diagnostic codes cannot be cleared.
There are some modules for sale by searching for 28556 41U00.
https://www.amazon.com/28556-41U00--.../dp/B00KTIEUX6
If you buy a used one, I doubt the seller will know what the history log contains. It takes Consult or NDS1 to read the log.
