Engine upgrade 05
Old Feb 16, 2018 | 02:56 AM
Panamamichael's Avatar
Engine upgrade 05
I have a 05 Nissan Maxima overheated because the fans were not working engine still run but burning oil cheaper to replace engine than rebuild but I wanted to find out if another upgrade engine for the Maxima or what can I do to upgrade instead of just getting the same engine again. I want to up a little better than stock engine but wanted to be affordable.
Old Feb 16, 2018 | 05:34 AM
MadMax07SL's Avatar
If this is a daily driver, trade it in for a lower mileage newer car with a warrantee. You're effort to "save money" on a replacement motor could land you into a world of ongoing trouble if you're not the skilled laborer doing the work. What I mean is, you get a used low mileage motor, get maybe a 90 day warrantee. Shop that puts it in gives you 60 day warrantee, after all it took a couple weeks to a month to get it and put it in. Something malfunctions outside the warrantee on the work and motor, you're back in the same place spending money trying to fix a 13 year old high mileage car. This would be different again, if it was you doing the work and you were very knowledgeable, then of course you would be saving money by keeping the car on the road.
Old Feb 16, 2018 | 05:37 AM
MadMax07SL's Avatar
Also to note, the bluebook of your car is likely worth less then the total cost of putting a new motor into it. Say you're car has a value in running condition of about $2500, of course now it's running poorly, so that drops to $1500 quick. Say you find a shop to put in the motor, out the door $2200. You're still driving a car with maybe a $2500 bluebook value.
Old Feb 16, 2018 | 05:00 PM
smittybizzle's Avatar
Hi, I would suggest a 09 up maxima motor or 08 up Altima 3.5 motor. The engine has HR heads and the DE bottom end. A little more HP minimal if any oil burning issues like out DEs.
Old Feb 20, 2018 | 05:32 PM
Two thing the engine has about 87,xxx miles , if I go with an 08-09 engine will it go in with no extra parts or what would I need to it.
Old Mar 7, 2018 | 08:44 AM
No you need a 09 up Maxima motor or an 08 up Altima 3.5. You will need a few extra parts Nisformance.com sells the swap kit.
Old May 2, 2019 | 02:40 AM
Found a shop that will do it for 3800 everything.with 2013 engine 52 thousand miles
Old May 2, 2019 | 04:07 AM
MadMax07SL's Avatar
And for $3800 the value of your car will increase by about $60 to $700 tradin. or you could scrap the car, and start over. That is still my recommendation.
Old May 2, 2019 | 04:24 AM
Yeah I spoke to a lot of friends and they also told me to get rid of it but at the end of the day spinning 3800 then spinning 15 to 20000 on another car
Old May 2, 2019 | 04:25 AM
My question is to those who have done the conversion what other issues have you come across after the swap
Old May 9, 2019 | 02:16 PM
04maximas's Avatar
its possibile but ya have to modify mounts, accessory brackets timing cover, use everything from the vq35de to the vq35hr
Old May 22, 2019 | 02:43 AM
Old Jul 18, 2019 | 07:22 PM
Just got it back
Wow drives great u can feel the difference.
Old Jul 19, 2019 | 07:50 AM
Tarzan's Avatar
What engine did you put in? Infinity?
Old Oct 26, 2019 | 06:48 AM
Newer Maxima engine 2012
So adding upgrades to the newer engine short ram and catback. Trying to get a y-pipe don't know what year y-pipe to get an 04-08 or 09-12 y-pipe.
heretic1
Mar 24, 2012 06:30 PM
carrrnuttt
28
Sep 13, 2009 03:26 AM
jruss1601
Feb 9, 2009 03:31 PM
bobjohnson
Jan 12, 2006 01:42 PM
hari_jay
May 28, 2001 02:39 PM
