PO110 obd code
Old Jul 5, 2019 | 08:10 AM
PH98I30's Avatar
PO110 obd code
So, yesterday I replaced my starter. The car runs great... no stalling, no rough idle and plenty of power. On my way to work this morning, my check engine light came on. It's throwing a PO110, intake air temp sensor code. Perhaps I didn't plug the connector back into the intake tube all the way. I can't imagine I damaged the sensor. Any suggestions? Jeez, the car runs like new.
Old Jul 5, 2019 | 10:47 AM
JvG's Avatar
JvG
Since that code was not there before, re-trace all your steps. Yes, I'd say that something is not connected, or a connector has corrosion.
Old Jul 6, 2019 | 12:46 AM
flynlr's Avatar
I had the wires pull right out of that connector recently when taking off the air box. ..so likely the connector is off or damaged
the wires came out of the sensor side not the connector to the wiring harness. and that will give that exact code.
Old Jul 8, 2019 | 09:58 AM
PH98I30's Avatar
UPDATE*** I cleaned the IAT sensor and connector with electrical cleaner, plugged it back in and problem solved.... no more codes.
Patm-a32
Nov 18, 2015 05:23 AM
Richy04
Apr 4, 2013 07:53 AM
Wil's95SE
Jul 31, 2005 12:29 PM
