Radio and clock no longer work. Help requested.
Nissan cefiro A32 1997
Battery from my car next day empty.
I checked the fuses but all OK.
So I ask myself where to found this problem.
Regards Jolyn
Perhaps something is wrong with the radio.
The problem might cause the battery to drain.
I would recharge the battery. Also find the fuse fie the radio. Remove that fuse.
It's possible that the battery will not drain after the radio fuse has been removed. If so, your problem is in the radio circuit. If not, the orole is somewhere else.
Just curious..... which country do you live in?
Thats what I'm thinking too.
Please remove the fuse.
Yes, the fuse is probably ok. It carry's electric to the relay and radio.
We want to stop draining the battery so that you can drive the car. That's more important than listening to the radio.
Removing the radio fuse is an experiment.
The experiment might help to isolate the problem.
Then you will know where not to look, as well as where you should.
I'm on the west coast of the USA. It's late here now, I'm going to bed.
Get your battery recharged, remove the radio fuse,
and let us know what happens.
Good luck.
Good luck.
fusible link nissan 1997
I read also that it's possible in de fusible link under the hood.
The battery is loading and I think tomorrow I try first the fuse.
I put my multi meter to look if still take power from the battery.
If I found it I let it know
Nothing found nissan 1997 a32
The battery is 12.6 volt.
when I take out the radio fuse multi mtr 0.06 amp.
fuse inside still 0.06 amp but what is going on???
If the car stands 1 overnight battery empty?
I don't know how things work in your country.
It's possible that your car is just fine, but your battery might need to be replaced. They sometimes develop an internal short circuit which will discharge them overnight.
When I have problems like this, I start by cleaning the battery terminals and the battery cable connections.
I understand that you tested how many amps the car draws from the battery. You probably did that by removing a cable and connected a multi meter between the cable and the battery. The amount of draw you mentioned does not seem very high.
It's also possible, though not likely , that your alternator has problems.
I'd have someone test that as well.
Battery
Thx for your answer,
I think that I order today a new battery, why because after 1 hour the volt going down from 12.6 till 10.5.
I don't connect on that time the - pole so I think end of the battery.
Quick after 2 1/2 year😩
Regards and I let it know
tomservo291
Mar 2, 2009 10:10 AM
RICOiz704
Sep 12, 2001 11:14 AM
