Wow 21hp from heads + cams
: Below is the link to a NA Z31 with ported heads and Motorsport auto 270 grind cams. Here are the mods the car has. I still have my 260 grind cams and orginal VG heads so I'll just look for a good condition VG 5spd. BTW does anyone want a Protorque high stall torque convertor? I have mine that only had 400 miles for sale. I don't believe I'll get an automagic, but if I did Don is only 35 miles from my house plus I have a stall convertor. With a 5spd I belive a VG wiht headwork + cams (260 grind) would do close to 155-162fwhp without tuning. A 270 grind is around 165-171fwhp, while the wildest 280 race grind should be around 170-180fwhp. But those 280 grinds would require an ecu reprogramming to idle right.
: List of mods: 240sx TB Pacesetter Headers Pro Dyno 2.5" full exhaust Electric Cooling fan conv. Stillen FPR Custom Cold Air w/K&N conical filter 88ss springs Tokico shocks on all 4 corners Yokohama AVS 50i's (avs intermediate)245/45 ZR16 z32 na rims with 1 inch adapters ACT Extreme clutch 2200lb pressure plate 85hp shot NOS Injector and Air/Fuel ratio monitor DMS rear strut bar MSD6a ignition w/Accel coil and wires port-matched manifolds and mild porting of the heads(reduced casting marks to increase flow) schneiders racing cams 274 durration with .440 lift removed wire mesh on air mass sensor, noticed a difference.
Originally posted by catman316
hey man, how much for the high stall torque converter?
what performance did you gain with it?
. The bad thing about the TC is that if you do only city driving it will lower your fuel economy slightly, but highway is unaffected. Be aware that the tranny has to be removed to install it so you should have the rear engine oil seal and both drive axle seals replaced at the sametime. The good thing about the TC is that when you combine it with a better gear(for us it would be 205/50-15s) you can run equal to or slightly better than a 5spd.
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
