People running n2o...
I'm running the NX Kit ( Thanks to tifosiv122 ) And I tapped my fuel line just after the Fuel Filter. Make sure you TIGHTEN the hose clamps, gasoline leaks aren't fun. Also, be prepared to mop up after you cut the line, cause there will be pressure in the line.
You don't want to see my setup, it is ghetto-fied. we had to use silicone gasket maker on the N2O 'noid cause it leaked. But I mounted the fuel solenoid on one of the strut tower bolts and I mounted the N2O Solenoid to the Strut Bar adjustment Bolt.
Here's pictures of MardiGrasMax's Install:
http://www.geocities.com/mardigrasmax/EngineBay.htm
Mar 12, 2020 12:06 AM
ballerchris510
Sep 10, 2015 09:35 PM
