SC guys who have run a 3.25 pulley
I had 3.25 installed today but my mechanics say the belts are rubbing against the SC housing or against some bracket or something! I have to go there to see for sure but has anyone else run into this problem? I ha to pay for them to pull down the SC to change the pulley...and now they put it back together only to have to pull it apart again because the belts are rubbing pretty bad! Can anything be done? Help!
Deac
Deac
Re: SC guys who have run a 3.25 pulley
Deac
Deac
Deac
Re: Re: SC guys who have run a 3.25 pulley
I need info from guys who have either the 3.25 or the 3.125 installedon their 5th Gens... I either need pics of how the pulley looks afer install or special instructions on how to install a 3.25 pulley so the belts dont rub against the sc brackets! Need help on this also ASAP..thanx!!
Deac
Deac
Re: Re: Re: SC guys who have run a 3.25 pulley
Originally posted by The New CLIMAX
check email, also try Keving
Deac
Re: what??
so...does that mean that the bracket is not supposed to be shaved? Have you heard anything different?
Deac
SHAVE THE BRACKET!
Originally posted by Y2KevSE
The belt does rub, but it's not as bad as you think it does. If you want, you can shave down the bracket a bit so the belt will clear.
Dremel...
Dremel...
Deac
kenc15
Sep 25, 2015 06:38 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
