Should I use bushings around Stillen RSB?
To prevent banging with the factory RSB (or whatever you call the cross bar between the rear wheels). I've seen pictures of the ADCO RSB and they use U bolts to tie theirs to the original cross beam.
Several posters have commented about banging noises when going over bumps. I was wondering if this wasn't due to the bar running close to the original. Seems like bushings around the rod would solve this problem. I could also consider doing the same as ADDCO. I did a search and did not find anything specific to the Stillen RSB.
On an alternate note, has anyone had any luck locating stainless steel versions of the socket end caps that Stillen uses with their RSB? I want to avoid them rusting in case I have to take them off. I've tried PepBoys, Kragens, Home Depot, etc. without any luck. Thanks in advance.
Re: Should I use bushings around Stillen RSB?
05RLS2
Apr 14, 2016 11:49 AM
knight_yyz
Nov 1, 2015 01:34 PM
