Question: Torque Setting on Pulley Bolt
Old Feb 27, 2002 | 01:55 PM
MichaelAE's Avatar
If using an impact wrench to tighten the bolt on the pulley, after a underdrive pulley installation, does anybody know the optimal torque setting for the bolt?
Thanks.
Old Feb 27, 2002 | 01:58 PM
MichaelAE's Avatar
One more question
Does anybody know the size of the bolt?
Old Feb 27, 2002 | 02:22 PM
Adboy's Avatar
140 lb-ft.
Don't know bolt size.
Enjoy the UDP- I do!
Old Feb 27, 2002 | 03:33 PM
MichaelAE's Avatar
Originally posted by Adboy
140 lb-ft.
Thanks, now I have to go down and figure out if I can get the wrench anywhere near the bolt or if I'm going to have to buy all sorts of little univeral joints and extensions to actually tighten it.
Old Feb 27, 2002 | 05:18 PM
MichaelAE's Avatar
140 lb-ft.
Hey, I just realized you have the same model as I...do you happen to have the sizes or part numbers on the replacement belts you needed. I know a couple of Maximas have discovered differences between models...would like to know what another AE needed to be sure.
Old Feb 27, 2002 | 07:49 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
140lbs and 19mm. you shouldn't use a gun to tighten it all the way unless you have an auto. i chipped a tooth on my flywheel trying to lock it. just bang it real tight with a good gun and boom your done.
lowpost99
Oct 26, 2025 06:53 PM
02PearlSE
Feb 1, 2016 12:37 AM
The Wizard
24
Oct 1, 2015 08:47 PM
dcam0326
Sep 18, 2015 04:52 PM
jcvgn
Sep 13, 2015 11:42 AM
