If YOU have JWT POPcharger read this
Old Mar 4, 2002 | 08:33 PM
iregula's Avatar
for those of you who have the jim wolf tech pop charger, after you installed it, did you guys notice a decrease in MPG's? mine might be like a small suv, im not sure if i installed it wrong. anyone experience same thing? if so how do i fix
Old Mar 4, 2002 | 08:35 PM
Keh mon's Avatar
Re: If YOU have JWT POPcharger read this
Unfortunately I haven't kept track of mine in a while. I think the decrease in mpg could be attributed to flooring it more often to hear the nice sound but that's in my case.
Old Mar 4, 2002 | 08:37 PM
iregula's Avatar
nope
nope i do everyday normal driving. its still horrible i installed it right too
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Re: If YOU have JWT POPcharger read this
YUP! gotta love that sound...it makes a slow car sound fast!!!
Old Mar 4, 2002 | 08:40 PM
xHypex's Avatar
With all my mods and a decently heavy foot I average 22-24 on the highway and 18-19 in the city. The least I have ever gotten is 14 after constant WOT, and even when I go to the track I average 18 or so
-hype
Old Mar 4, 2002 | 08:42 PM
maxedout95's Avatar
I have my for about 4 months now and I don't really see a difference maybe a little less MPG then before but then again in the winter I always get low miles so I have to see in the summer it should give me more MPG's I hope.
Eric L.'s Avatar
I didn't notice any mileage difference after I added my JWT cone three years ago.
My car has always gotten lousy mileage though. I think it has more to do with the driver (i.e. lead footed me) than the car.
Old Mar 4, 2002 | 08:49 PM
PhatGuy
Did you reset your ecu after install?
Old Mar 5, 2002 | 11:41 AM
iregula's Avatar
ecu
is that unplugging the battery for 2 min? what exactly will resetting the ecu do
Old Mar 5, 2002 | 01:16 PM
Colonel's Avatar
Old Fuddy Duddy
Re: ecu
If you have a 2K+, you should do it over night (unhook the battery). If you have a 4th gen, I believe there is a specific way to reset the ECU inside the car, but since I have a 5th I am not 100% sure. Check around the site if you have a 4th gen....its been explained.
Old Mar 5, 2002 | 01:29 PM
NotNew!!NewSN!!'s Avatar
after i put the hybrid from my CAI in ive been gettin some real sh**** gas mileage, should i hvae reset the ecu after i switch from CAI to hyrbid?
Old Mar 5, 2002 | 02:46 PM
DaBoxSE's Avatar
I havent really kept track really, but at first I dont think there was much of a change and that was a year and a half ago, but now my mileage has gotten really sheitty. I need a tuneup badly I guess.
Old Mar 6, 2002 | 01:44 AM
DSimple1's Avatar
Ive been keeping track of my mileage every time I fill up since I bought the car 2 years ago. I averaged about 24-25mpg before adding the pop charger, once added, I didnt see any change at all. Then when I threw on the exhaust stuff, my mileage went down, but thats when winter hit, so obviously it would go down. I keep up with the regular maintenence things like replacing the fuel filter, spark plugs and such. On a couple occasions I have been able to pull about 32mpg just straight highway driving, averaging about 75mph.
BTW I havnt reset the ECU either since adding the goods..
Old Mar 6, 2002 | 08:18 AM
got rice?'s Avatar
on all the cars I've added aftermarket intakes on, all have seen mpg improvements since you increase the engine's volumetric efficiency.
as someone mentioned, mpg will drop during colder weather.
Old Mar 6, 2002 | 08:25 AM
dwapenyi's Avatar
My mpg drops during cold weather, but I find that really really strange. In colder weather, the air is denser, so the car should run more efficiently. This has always baffled me.
The only thing I can think of that would hurt mileage in winter is that cold weather makes all the viscous fluids, well, more viscous. The wheels may be more resistant to rolling, the oil in the pan may be a bit thicker etc.
DW
Old Mar 6, 2002 | 11:38 AM
yes this is all happend sicne we got a second wind of winter here in pitt, thanks for clearin it up i used to get like 300-310 a tank, but last 2-3 weeks have had about 250-260 at most, must be the winter
Old Mar 6, 2002 | 12:39 PM
GTRBlkMax97's Avatar
Re: Re: Re: If YOU have JWT POPcharger read this
What car is in your sig?
Old Mar 6, 2002 | 10:02 PM
got rice?'s Avatar
during the winter months, you are using fuel that uses more ethanol (to meet the oxygenate leves) that are causing the drop in the gas mileage. The Federal Clean Air Act requires this fuel from Oct 1 to Jan 31.
Old Mar 7, 2002 | 07:00 AM
dwapenyi's Avatar
OK. That explains it. I forgot about that. That's the stuff (MTBE)that has back-fired big time for the EPA. Modern cars try to compensate for that crap and end up getting worse mpg (as this thred has attested) and, MTBE has shown itslef to be environmentally un-friendly as well, seeping into and dmaaging water tables.
MTBE be GONE dag nabbit!
DW
Old Mar 7, 2002 | 07:20 AM
got rice?'s Avatar
if we all start riding our Razor scooters to work, the world would be a cleaner/better place
Old Mar 7, 2002 | 05:01 PM
Bman's Avatar
Maybe you should start selling those too just like other rice shops!
Old Mar 7, 2002 | 08:24 PM
libo74's Avatar
Producto Colombiano
i know this is a stupid qustion but can somebody explain how to reset the ECU. i already search, but i didn't get a straight/clear answer. i would really appreciate any help.
thanks
btw i am going to install a JWT pop-charger, and i have a 96' auto
Old Mar 7, 2002 | 08:55 PM
tm96max's Avatar
Go here: http://vbxmaxima.8m.com/ecu.html it explains it all.
Thanks to vbxmaxima!!
Old Mar 7, 2002 | 09:13 PM
got rice?'s Avatar
disconnect the battery for 30+ minutes
Old Mar 8, 2002 | 05:35 AM
dwapenyi's Avatar
If you're going to dis-connect the battery, you have to do it for 24 hours in order for the ECU to completely forget. At least that's what the FSM says. The quickest way is to use the screwdriver method to reset it.
DW
Old Mar 8, 2002 | 11:03 AM
Tubbed'65's Avatar
DW
when its cold the ecu makes the engine run rich, commonly called choking it. Carbs used to do this by choking the air off and adding fuel, richening the mixture. There's a number of variables with injected cars, bottom line is fuel, the ecu runs rich while the engine is warming to operating temperature. This denser air you speak of has minute effects.
Old Mar 8, 2002 | 04:07 PM
libo74's Avatar
Producto Colombiano
thanks for the info bro. that is the clearest answer i have gotten.
Old Mar 9, 2002 | 11:21 PM
iregula's Avatar
do u guys know why winter is so bad on MPG and if summer gets better? i thought colder air was dense and good already. i still have poor mileage on my car w/ just JWT pop. no hard driving either.
Old Mar 10, 2002 | 03:47 PM
got rice?'s Avatar
read my post above about ethanol
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
