disabling stock alarm
i heard it in the other thread so i decided to post up a new thread
about it... you know how if you lock the car before you close the
doors then arm an aftermarket alarm
later when you open the doors the stock alarm goes off
its quite embarrassing... any fuses i can pull or wires i can cut
or ground to disable the whole stock alarm?
im tired of showing off my alarm to girls and then having the
stock alarm start honking the horns...
haha im juss being an idiot
but i do have a lot of plans for the alarm itself
when i have time im gonna put in window/sunroof controls
and remote start
i'm lazy tho
pull the plug eh, thats probably why i couldnt figure it out
its waay too obvious for me
and remote start
i'm lazy tho
Originally posted by PDubs
Pull the plug, pull the plug! And what do you mean by show off? Just exactly how good is your alarm system? I have a good one on my Stang, just want to know what features I'm missing. =]
disable stock alarm
To disable your stock alarm you need to go to radio shack and get two-50 volt diodes (they come 2 in a pack-costs like 60 cents) the diodes have stripped ends and non-stripped ends...solder the stripped ends together along with a wire that will go to the door unlock signal wire from the after market alarm. and solder wires to either end...then one end goes to the unlock wire and the other end goes to the factory alarm disable wire SOLDER ALL CONNECTIONS WITH THE DIODES they could just pull out if you dont
unlock--------------------====|=(stripe)------- X
fact alarm disable--------====|=(stripe)------- X
X= solder these ends and to alarm signal
unlock is light blue with silver dots at the harness from the door
fact alarm disable is light green and black with silver dots at the anti-theft module
and remote start
i'm lazy tho
and remote start
i'm lazy tho
Originally posted by vyper0
It is as simple as that...works in my car
What you did seems to be pretty much what I did on mine. Except I only used 1 diode.
ok im gonna go grab the factory disarm wire,
hook it up to the (-) unlock output on the alarm
just curious, what is the diode for? to prevent
the positive lock output from damaging the module?
so logically it will disarm the factory alarm when
i disarm my alarm, correct?
that sounds about right, right?
When I had my 3rd gen the diode was not working and the installer had to call dei to figure out what the trouble was, it turns out that all you needed to do was ground the hoodpin so that the factory alarm always thinks that the hood is open, thus not allowing the factory alarm to set.
the diode is there to prevent current from passing from the stock unlock to the stock disarm when you dont want it to
say someone broke your window and then pushed the unlock button on the inside of the door rather than pulling up the lock ****
this would then also disarm the alarm
no bueno
that's why the diode is there
SEARCH!!!!!!
I've posted this many times before too
no bueno
SEARCH!!!!!!
no bueno
SEARCH!!!!!!
The man has spoken.
no bueno
SEARCH!!!!!!
no bueno
SEARCH!!!!!!
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
