***i N D I G L O G U A G E S***
***Indiglo Guages***
Greg on custommaxima.com used to sell 6 color indiglos. I want to know what part is the switch. Is it the peice that has a blue, green, silver and black 1/4 circle? Do they make any annoying humming or buzzing sounds. I have notice that some indiglos have a hole for the low fuel light. Do I have to get the ones that have the cut out for the light?
I have a 97 SE.
Thanks for your help
I have a 97 SE.
Originally posted by MAXINXS
How are the reversed indiglos different from the regular ones?
example of reverse
http://secure15.dellhost.com/~d30022...97M-SF-REV.gif
regular
http://www.autodynamic.com/images/EGNMAX8994-125.gif
Originally posted by NYBlakMaxx
They cant find freakin reverse indiglos for my 99 GLE. WTF!!!!
Yes, get reverse indiglo. I have the 6 color indiglo and its not really 6 colors. I never use then either. I just turn them off nad I have a white background with lighted neddles. Looks pretty kool to me like that. Indiglo will eventually crap out on you too. Resistor or capacitor or something like that usually only lasts for a year or two. The only people that turn on my guages are my friends.
6 colored is real hot, especially when it's real dark at night and you have them shining on your face, then a car pulls over next to you and see's mad light in your car...i got a number like that
Originally posted by Toolrocks
I prefer the reverse indiglos. They are easier on the eyes and are newer so fewer people have them.
Say I'm driving from NY to FL mostly in the night, will my eyes start to hurt or burn because of the bright glow?
Originally posted by Maximum97
So the indiglo is too bright?
Yeah, you can dim the indiglos but they just still seem bright to me. Personally, I like the idea of lighting up the numbers, not the background. Plus the colors of the reverse indiglos will better blend w/ my other interior lights. I'm a little worried to hear that they may wear out in only a year though. I don't want to take my cluster out and apart again after I install them. Oh well, we'll see.
When you put on your lights, does the indiglo guages light up indiglo or the regular black and there is a seperate switch to make them light indiglo? I'm confused. On the 2 color, I've noticed that there is a switch on it, I am thinking that you can use them black or indiglo whenever you want?
I hope I explained myself correctly.
Originally posted by mzmtg
Or you asking if they can light up like the factory style or all indiglo?
They can't they are either indiglo, or off.
But when I remove the factory white faces won't the bulbs still be part of the guages? Can't I run a seperate switch for the indiglo,
I want to use the black when the lights are on and indiglos off. Then when I want, put the indiglos on.
Understand?
Understand?
Understand?
The indiglos are layovers. They go over you factory gauge faces. Also, they are not transparent so no light will shine through them from behind. WIth the reverse indiglos though you'll probably want to leave the bulbs in so that the needles and miles driven are still lit. Hope this helps.
Can't the factory faces be removed so my idea can work?
