VQ30DE with funny gas
Hi everyone,
Just had my NOS kit installed today, and that thing feels awesome, I almost finished the whole bottle the first day, it's kinda addictive
Hopefully next week, i'll upgrade my fuel pump.
Re: VQ30DE with funny gas
Originally posted by 97maxima
Hi everyone,
Hi everyone,
What shot are you running, 50?
Did you get any gauges?
Hi everyone,
Hi everyone,
Hey 97Maxima, I looked at your profile, and
I see that you're in Philly. Did you get your nitrous installed at a shop? If so, how much did you have to spend for the install? or if you bought the parts and got'em installed at same place, how much was it? I"m only looking for a 45 - 50 shot because I dont wanna have to buy gauges or stronger fuel pumps.
please reply back!! thanks.
Originally posted by 95emeraldgxe
how much does it cost to refill a 10lb bottle......and where would u get it refilled?
Hey Guys,
The NOS kit is 5124, and I started with a 50 shot, just to test it out before I change to a bigger jet, and upgrade my fuel pump. I got a bottle pressure gauge.
I live in Philly, but I got my kit installed by a friend of mine in NY. It costs about $40 to refill the bottle (but it's worth it
Hey Guys,
Hey Guys,
No2 suggestions
We drag race with NOS kits on 4 cyl dragbikes all the time with 50-
200 hp shots.
Looking at the catalog it looks like you use the fuel injection as the gas enrichener to compensate for the increase in oxygen.
Bottle pressure is important for consistency. We like to see 900 psi
less pressure, less No2, less power. Don't over pressurize.
Preignition is the enemy. Check a spark plug after a hard run and see if it has any small bits of aluminum. Use a magnifying light.
No alum. no problems.
We have used nitrous controllers which retard the ignition when No2 is activated. 4 deg per 50 hp. Your knock sensor will probably retard the ignition. More experienced guys out here can clue you in.
200 hp shots.
Re: No2 suggestions
200 hp shots.
200 hp shots.
Re: Re: No2 suggestions
Originally posted by JAIMECBR900
On max's you cannot retard the ignition w/o reprogramming the ECU specifically for the N2O setup. Ignition does not seem to be the problem that most of us are running into, leanness is. That's the reason to upgrade to a high volume fuel pump and two step colder plugs when going over 60 shot of N2O. Detonation is definetly the enemy that is the reason for all the gauges and precautions so that the engine does not blow up. Probably more than anything though not enough fuel/fuel pressure is going to cause most of the problems.
How is the NOS injection hooked in on a maxima? Anybody have pictures? I'm really only familiar with the Fogger Nozzle style of NOS.
Thanks for all the advice guys. I'm new to nitrous oxide so I will def. do more research about it. I heard that we can use the 300ZX spark plugs because they are like 1 range colder, is that true? are they the same plugs between the N/A and TT?
litch
123
Jan 4, 2024 07:01 PM
ef9
Oct 4, 2015 08:43 AM
