20 in rims
20 in rims
I have a 2 in intrax drop and i might be buying 20 in rims from my boy. the tire is a 255/35 . will this fit?? if not what should i do. im gettin them for a great price. i need info
Re: 20 in rims
Please do a search first. So far, it sounds like you're gonna get somethin like my rims/tires. If the offset is around 38mm it should fit.
You might have a hard time fitting if they need to be tucked under your fenders. I have 9.5" wide rims with 265 and it is just about flush with the fender on the back and slightly sticks out of the front due to the nose of the maxima curving in a bit. i don't have a drop, but if i had a drop it would be hard to imagine these tucking inside of the fender. you may need to roll your fenders. check out my homepage for pictures.
btw, if it's from a friend of yours, just try them on for a test fit if you can. that's the only way to know for sure. good luck and if it fits, i'm sure it'll look tight.
0m3nc0w
Sep 11, 2015 05:21 PM
