Need Help... Will these rims Fit?
Originally posted by i30dude
I really need to know... I30 and max are the same guys
jhlee
So should i get the rims? I know some one here knows...
5 X 114.3? can it only be that?
5 X 114.3mm = 5 X 4.5" too
For more information...
CLICK ME
and select BOLT PATTERN... there are other selections that will help with some of the lingo.
Hope it helps.
ok, does 5x114.3 mean 18x8? if they are 18inch
The offset of your OEM wheels is +40mm.
A +42mm offset wheel will be "tucked-in" (further toward the centerline of the vehicle) than the OEM wheels (+40mm) by 2 milimeters.
(The higher this number is, the more tucked-in the wheel will appear, the lower it is, the more the wheel will stick-out from the wheelwell).
Will the wheels you specified fit your car? Yes.
Will they be the best choice? Hard to say - many people prefer to either match the OEM offset, or move the wheels slightly "out" or away from the centerline of the vehicle, which enhances both looks and handling characteristics. Personally, I would choose either a +38mm or +40mm offset for your application, but that's just my opinion.
As someone else said though, your tire choice is the other half of determining correct fitment in the wheelwell. Choose a tire that has as close to the same "overall diameter" or "OAD" as your stock tires, so you retain correct speedometer/odometer readings.
PS: You might consider doing some research on basic wheel/tire terminology/specifications, so you have a better understanding of what all the variables are: that way, you can make an educated decision & the one that's best for your car, instead of relying exclusively on random advice on the .org for this important decision.
Check out:
www.tirerack.com
http://toy4two.home.mindspring.com/offset.html
Good luck w/ your choice!
Check out:
www.tirerack.com
i'm positive they will fit
my rims are 18" and are 8.5" wide...i measured it and if you want a pic, email me at thaholycity@aol.com or just hit me up on IM later on today (i'm at school now studying for finals...dam maxima.org always taking up my time
but i'm positive it will fit
)but i'm positive it will fit
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
