When you put the car on jackstands....
where do they go? cuz the regular jack has a spot where its doubly reenforced. to the left and right of the regular jack spot is all plastic, no? the reason im asking is i have to rotate my tires, and its cheaper to go buy 4 jackstands and do it myself.
Re: When you put the car on jackstands....
Re: Re: When you put the car on jackstands....
Originally posted by ljl10
Raise the car with a floor jack and place the jack stands in the exact same places that the scissor jack goes. The lip on the car with the two notches on either side should be resting on the jack stand.
You can jack the rear of the car up by the middle of the suspension beam and the front by the crossmember under the engine.
Re: Re: Re: When you put the car on jackstands....
Originally posted by mzmtg
If you put the lip on the stand, it will bend. I put the stand just inside of the lip.
thanks very much. i did not know that.
Re: Re: Re: Re: When you put the car on jackstands....
I've done it many many times this way and I have never had any problems with the lip bending. Hmmm....
Amateurs!!!!! Papasmurf did a quick tire rotation at a restop in Laurel, MD on our way to Carlisle a few weeks back....all he used was the OEM scissor jack!
I've never seen one whole side of a car lift up with a single scissor jack!
Just takes 5 easy steps
1. Jack up the left side and swap front and rear.
2. Same thing on the right side.
3. Swap the right front tire with your spare.
4. Jack up the left side again and swap your left front with the right front.
5. Jack up the right side one more time and swap the spare with the left front.
would you like to explain how he did it? cuz the tires gotta go all crossways. and whered he put the jack? if its just that easy ill go do it right now!
he did this on BOTH sides of the car with ease! it might be in his suspension setup though...he has Cattman coilovers(not sure if that matters though), but they looked to be in the lower position than stock...wierd! ask Cutlr7 and Rolondo(other DC guys) they were both there to witness this...
all he did was put the scissor jack about a 1/3rd to midway on the rail and jacked it up..I was in disbelief when I saw both tires were free off the ground!!! :
I once did a rotation with only one scissor jack too. However, I pulled the temporary spare out, removed one wheel, put the temp spare in place and put the lugs back on (tightened by hand). Then proceeded to the next tire, jacked it up and removed it, replaced with the one I took off first. Moved to the temp spare and removed it, replaced with the 2nd tire.
Repeated on the other side.
Man, longest time it took me to rotate tires .. what can I say, good ol' college days
yah man im just a po' college kid... did my oil today, ill do the tires tomorrow... i totally forgot i could use the spare to hold a spot. thanks a lot guys! oh and i know this has nothing to do with the original post, but when i used to have $ and go get my oil changed, they always topped off my fluids... what do i have to do, now that im doing it myself? i shoulda been paying attention...
Buy
1) premium power steering fluid (don't get the Honda-type, it's different)
2) premium DOT3 brake fluid
3) Premium tranny fluid
4) Check if you need coolant.
If you're curious, I am using Valvoline power steering fluid & Castrol DOT3 brake fluid. I didn't get any tranny fluid coz I took it to the shop and had them top it up for $2. Worked for me.
Check tire pressure. Inspect for leaks. Don't forget to change your oil drain washer the next time you change your oil if you notice leaks around the drain plug (or it could be your drain plug. It's cheap, get a new one).
To check auto tranny fluid: drive around for a little while and check the fluid level with the engine running in idle, neutral/park after a few minutes.
To check engine oil, COLD engine ... do it in the morning before you start your first drive.
To check power steering fluid, look at the markings on the reservoir, there's one for hot and one for cold. Same thing for coolant reservoir tank.
Originally posted by harry
Hmm... I guess you guys can't lift the whole side of the car from the front jack points? Works with my Altima. I guess that's one of the benefits of having crappy weight dist.
If I'm working under the car I use the rails that go front-back closer to the middle of the car for the stands.
Atlanta guys
You guys can come to my new home I have a garage now and the big 3 1/4 ton jack and 2 jack stands it will only take 5 mins to jack the car all the way up and also an impact wrench to speed the process up.
Lakersallday24
Jun 16, 2019 01:35 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
kirkhilles
Aug 8, 2015 10:53 AM
