Rim Width.....?
Originally posted by Igor911
nice! those r gonna be some PHAT rims and tires if you can get them to fit!
Originally posted by Newman
someone has x 9.5 wheels on his 5th gen. ill look for the post
his name is Kanaka
he has 17 x 9.5 rims with 265/40/17 Kumhos
http://forums.maxima.org/showthread.php?threadid=114540
Originally posted by max'n out
9" will fit 8.5 will fit 255 wide tire will fit, so long as you get the right offset, say 39mm to 35 mm.
http://www.uniqueautosports.com.au/i...MVC-001F_6.JPG
Originally posted by 2K1HoMax
please explain to me exactly what u mean my offset? i think u mean how think the tire will be but im not sure, im goin down to atleast 19/255/35,, maybe even 30 if thats what u meant, heres what the rims look like...
offset it how far off center the lugs are from the center of the rim.
http://forums.maxima.org/showthread.php?threadid=120190
If you do not use the correct offset
you tires could rub, or they good stick out past the wheel wells which looks really shi tah. Either way I suggest you really use the search function and do some research before you make a purchase.
A zero offset will suck...the offset you want is 35mm-39mm asuming you want the flush look with the fenders...With a 9" wide wheel you don't really want to run less than a 245 and a 255 should be good again with these offsets. 255 is the width of the tire, 35 is the aspect ratio of the sidewall compared to the width (meaning it's 35% tall of the total width of 255)...35 will be fine.
does he want -35 to -39 or just 35-39?
He wants anything between 35 and 39mm meaning 35mm, 36mm,37mm, 38mm,39mm, not to say others wount work or don't look good but thats the range I think he should stick within.
Considering there is no such thing as 35-39
no no, i meant does he want positive or negative?
0m3nc0w
Sep 11, 2015 05:21 PM
