help me change Drive belts PLease...
how do u loosen the main drive belt i cannot find it my haynes manual is pretty indescriptive. i am olny 17 and i don't kno that much but i wanna learn. i loosend the idle pully, thinkin' it was gonna loosen the belt (laugh i kno) now haha it makes weird noises. i don't have to loosen up the power steering pump screw. do i? Well if you know how to loosen up the belt to remove it, please just try to explain how i will be able to build off what you tell me. THanks For any1 who helps, i appreciate it!And today is my birthday the 28th!
You have to loosen both the tensioner pulley center bolt AND the adjustment nut from above (at about the 1 O'Clock Position).
I'm not sure about the PS belt off the top of my head though.
[i]I'm not sure about the PS belt off the top of my head though. [/B]
The tensioner can be reached from the underside of the car. You have to try various combinations of extensions, swivel adaptors, etc., and then snake your tools and hand up to reach that tensioner. that and a lot of patience. I didn't use any special tools to remove the PS belt.
There is another bolt that you have to loosen before you start turning the tensioner. It's just above the tensionser head and, if i remember it right, it's easier to reach it from above.
good luck!
good luck!
Originally posted by BenBlanco218
Does anyone happen to know? I actually know that you need to loosen 2 bolts, but I need to know what kind of 12mm tool to use since a socket wrench is impossible to fit. I'm stuck at the point where I have taken the first belt off but need to emoe the power steering belt in order to proceed in the UDP install. Someone help me out. Thanks.
tsi6001
Oct 3, 2022 10:23 PM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
