Painting plastic valve cover ???
Re: Painting plastic valve cover ???
Originally posted by Krash513
Ive done my searching but all i need to know is what grit sandpaper should i use to sand it before painting?? Thanks
I did not sand mine, just painted it and let it cook in the sun to harden it. I used hi-temp paint.
I thought the valve cover was under that?
I thought the valve cover is aluminum (sp) ?
PM alphaoenz (he did his like 5 times)... thanks to me I screwed up his valve cover...
We did fix it, for the most part, by using a fairly fine grit sand paper, but it was one of those situations where we just took whatever we had and went at it
I suggest cleaning / sanding / cleaning again / base paint / paint
- Matt
.I suggest cleaning / sanding / cleaning again / base paint / paint
- Matt
valve cover
i cleaned mine cover really good and the paint still would not stick in some places so i sanded it with 800 grit and the with 1000 grit. it turned out good...if you and a picture go to my home page.
I already tried it once, a bright red too, i cleaned it, taped off the nissan and the 3000 part, sprayed on the paint and it wouldnt stick, so i ran for the paint thinner..... guess ill try a very light sanding and try again... thanks guys
You need the correct paint. Go to your local hobby store. Buy paint made for plastic models. The brand I got was Testor. Do few light coats and then follow it with one heavy coat.
JoshG
51
Sep 21, 2015 10:41 PM
Max139617
Sep 20, 2015 07:09 PM
