how much to install y pipe at midas?
Old Jun 7, 2002 | 05:58 AM
95maxred's Avatar
How much is it to install a y pipe at midas? And when i do get a y pipe should i remove my resonator too? WOuld it be to loud with a stock muffler?
Old Jun 7, 2002 | 06:59 AM
tifosiv122's Avatar
Re: how much to install y pipe at midas?
Most won't install the Y
Erik
Old Jun 7, 2002 | 07:11 AM
NmexMAX's Avatar
dot dot dot ...
Got mine installed at a local muffler job for $75, I regret it now though, just do it yourself, it's easy. I helped a friend do his, and now regret not doing mine on my own.
Old Jun 7, 2002 | 07:14 AM
blizz20oma's Avatar
I'm so hood
Isn't 90% of the fun in modding out your car doing the work yourself and learning more about cars?
Old Jun 7, 2002 | 07:25 AM
_DRU_'s Avatar
yea, most wont do it because the OEM Ypipe has precats on it. but you can get a ghetto shop to do it for 30 bucks cash.
Old Jun 7, 2002 | 07:45 AM
Finality's Avatar
Also dont' forget that if your bolts are rusting there is a chance they will break off.
Old Jun 7, 2002 | 08:35 AM
NmexMAX's Avatar
dot dot dot ...
Especailly if it is a 95. It's older so they maye be more likely to break off.
I agree 100%
Old Jun 7, 2002 | 09:40 AM
Str8ridin's Avatar
Midas *if they do it* will charge $60, give or take. Usually, they see it as an hour job and will charge you their hourly rate. Smaller private places *more likely to do it* will charge less, between $35-55 if you shop around.
Old Jun 7, 2002 | 11:19 AM
brodaiga's Avatar
agreed
Old Jun 7, 2002 | 01:26 PM
FLO_BOY's Avatar
OK, so now you know about the install...
As for the noise, I have a budget Y-Pipe and a stock muffler and I
have to tell you -- it's still quiet -- but, there is JUST a little amount
of rumble...DAMN, it sounds good!!
FLO_BOY
Old Jun 7, 2002 | 06:19 PM
FJC's Avatar
FJC
The boyz at Meineke in Lynn hooked me up for 50.00 entire cat-back. I helped out though. A Y might be around 30.
Old Jun 7, 2002 | 06:58 PM
puremax's Avatar
I remember awhile back you were having a problem with your y pipe? Did you get that probloem resolved?
Old Jun 10, 2002 | 01:51 PM
Str8ridin's Avatar
Yeah, since the pipe (even after sending it back) still didn't fit, I found a guy who was able to work with the pipe and my car and make it work with out dimpling/cutting or other performance robbiing techniques.
In retrospect, I paid mad money, had downtime on my car and wasted a lot of my time for 10 extra horses and a lot of noise?!
Old Jun 10, 2002 | 02:43 PM
maxima168's Avatar
i heard there is different specs. how can i find out if my car has a federal specs or the cail specs? does it matter?
Old Jun 10, 2002 | 02:46 PM
FLO_BOY's Avatar
check your VIN#, and then use the SEARCH function to figure out stuff
on your VIN in particular.
Hope this helps!
FLO_BOY
Old Jun 10, 2002 | 05:00 PM
meccanoble's Avatar
Sports Button FTW
meineke said it would be 85! F them
BkGreen97
Apr 2, 2016 05:47 AM
Violator
Sep 9, 2015 10:14 AM
Samedi
Sep 3, 2015 01:07 PM
